01-16-2017, 08:43 PM | #1 |
Rep 110
Drives: F30 335i
19x8 front 19x9
Anyone running this setup? Found a deal on some CH-R but some weird size.
2012 F30 335i | M Preformance Aero | Borla ATAK | KW V1 | R1 Slotted & Drilled Rotors + Pads | Injen intake | Bootmod3| VRSF DP | ER 7" Comp FMIC. --- @slow_f30
01-17-2017, 12:33 AM | #3 |
Rep 110
Drives: F30 335i
01-17-2017, 04:12 PM | #6 |
Rep 110
Drives: F30 335i
01-17-2017, 11:50 PM | #9 |
Rep 5,140
This is a great setup if you, like me, want to avoid the stretched tire look!
RWD or xDrive on your car? With RWD you can fit 245/35-19 front and 265/35-19 rear tires on those wheels. Will look great! With xDrive either stick with OEM sizes, 225/40 front and 255/35 rear or go wider with 245/40-19 front and 275/35-19 rear. If you like them more aggressive you can always buy genuine BBS hubcentric spacers. BBS part numbers: 09.31.371 - 5mm 09.31.369 - 10mm |
iseven30.00 |
01-18-2017, 02:15 AM | #10 |
Rep 110
Drives: F30 335i
thank you for all the replies guys. helped alot.
