07-30-2009, 06:39 PM | #1 |
Rep 3
Stereo Stops working
hey,
Sometimes when I shut off my car and start it up again the stereo does not work. Only clock is displayed. Nothing works, no bluetoothe, cd, sat, radio, or usb. It goes away after a while with the car turned off. I remember seeing a thread about this but lost the information. I read in the thread that there is a SB out regarding this issue. Apparently it is a coding problem. Any info would be great. 2009 328xi |
07-30-2009, 06:41 PM | #2 |
No longer moderate
325
Rep 4,401
You're correct there is a SB - code is the issue but AFAIK no resolution yet. You're dealer should be made aware of your issue (so it's logged - for your protection ; -).
07-30-2009, 07:08 PM | #4 |
No longer moderate
325
Rep 4,401
Yup - found the info I posted on a previous 1er thread:
SI B 65 12 09 - dated April, 2009 Model: E82, E88 (from start of production) and all the E9xs (from 9/07 builds on) Situation: The radio is intermittently inoperative with the ignition on. Only time and date displayed (not true in my case - the display goes blank). No audio output. Radio operates correctly when switched on again after sleep mode. Cause: Software issue in RAD2 (the Professional HiFi - option 663) |
