BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > car vibrates after putting e85 in
      10-03-2017, 02:42 AM   #1
Mfronce
Drives: 07 BMW 335i
Smile car vibrates after putting e85 in
I have an 07 335i that is tuned. I just switched the map to e85 from 91 octane. Car is handling it fine until I slam the pedal to the floor. There is no lag, no weird noises or anything until I let off the gas. Car is fine coasting but then when I accelerate the car vibrates/shakes horribly. The car will vibrate after I come to a stop while it's idling. Turning the car off and back on cures the problem completely..until I floor it again. I have let it idle after accelerating hard. I have also revved in neutral. The only thing that cures the problem is turning the car off and back on. I'm thinking this is a computer issue? I just filled up with my second tank of e85 since changing the map. This did not happen before when I switched to 91 octane from e85.
      10-04-2017, 11:59 AM   #2
Orion4
You may have more success with responses on the E90 Board than here.
http://www.e90post.com/forums/index.php
335i, e85, n54 335i, tuned
