BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > 335i Exhaust Installed on 328i (pictures and video attached)
Studio RSR
      01-02-2014, 09:59 PM   #1
TurboM
TurboM's Avatar
Drives: 2018 F82 M4 ZCP
I know this has been done before a few times but just figured I'd share my experience with some pictures.
Parts used:
- OEM 335 axle back exhaust/muffler
- 335i rear bumper diffuser
- OEM BMW muffler clamp (for F30 328i - 75mm)
Since the 335 piping near the muffler is 5mm larger than the 328 we needed to add a small piece of piping to the muffler side of the piping in order to use the factory 328 clamp. It was a bit tricky to align the piping due to our initial cut not being in the ideal spot. This resulted in about 30 minutes of extra fabrication work but ended up working out fine. I suppose it would be much easier just to weld everything but I needed this to be reversible (I can reinstall the 328 muffler and rear diffuser in about 15 minutes).
Overall the car sounds MUCH better. Pretty loud during cold start, and has a nice rumble during idle and normal driving conditions but not too loud at all. I also have a catless downpipe installed which I'm sure adds to it a bit.
Appreciate 6
thezarb14.00
d_a_m92.50
thatf30136.50
AndrewC198910917.50
JDAURIA725.00
      01-02-2014, 10:25 PM   #2
lmcq784
Excited F34 owner
Drives: '14 F34 (328iX GT M-Sport)
Looks great! This gives me hope!!
I have a 328GT that I would eventually love to have 335-style or quad tip exhaust eventually.
      01-02-2014, 11:20 PM   #3
slmdgee
Usofstance
Drives: 328I 6SPD
How does your's sound?
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      01-03-2014, 12:25 AM   #4
LAwolverine
LAwolverine's Avatar
Drives: Cannondale
looks great!! how much did this run you?
      01-03-2014, 12:54 AM   #5
USC2000
USC2000's Avatar
Drives: F30 328i M Sport
Nice work. Looks really good.
lmr126.00
      01-03-2014, 05:23 AM   #6
mge92
SPEED RACER
mge92's Avatar
Drives: BMW X5 M50d BMW M2 CS
Would there be any issues with putting the 35i exhaust on a 28i engine? Was thinking about doing this on an X3
      01-03-2014, 10:56 AM   #7
TurboM
TurboM's Avatar
Rear Diffuser - $200
335i Muffler - $85 (+ $60 shipping cost)
Muffler Clamp - $65
Welding/Labor - $120
      01-03-2014, 11:03 AM   #8
slmdgee
Usofstance
Drives: 328I 6SPD
Muffler Clamp - $65
I paid 125 for my 335i muffler and i did the work myself.. saved a lot.
      01-03-2014, 11:09 AM   #9
LAwolverine
Drives: Cannondale
Muffler Clamp - $65
where'd you get that diffusor for $200? i'd also like to know if there are issues with using a 335i muffler on n20/n26
      01-03-2014, 11:09 AM   #10
TurboM
TurboM's Avatar
Yeah, if you don't need it to be reversible you could weld the muffler to the mid pipe and also cut the factory rear diffuser. This would have cut the cost in half but was not an option for me.
      01-03-2014, 11:11 AM   #11
TurboM
TurboM's Avatar
It's just a muffler. What would be the issue?
Diffuser was purchased off eBay. Looks and fit perfect.
      01-03-2014, 11:35 AM   #12
LAwolverine
Drives: Cannondale
You're right, i didnt think that that through haha. Looks great man! Do you remember which ebay seller it was? The only ones I've seen have international shipping for nearly $200
      01-03-2014, 11:42 AM   #13
TurboM
TurboM's Avatar
Sent you a PM
      01-03-2014, 02:08 PM   #14
rayg
Drives: 435i
$470 for a new exhaust and a diffuser? That's a great deal! Looks good, debadged it looks just like a 335i.
      01-03-2014, 03:51 PM   #15
slmdgee
Usofstance
Drives: 328I 6SPD
yeah ours sound exactly the same! Good stuff.
      01-03-2014, 05:45 PM   #16
momo3605
Drives: M340i LCI, 718 GTS 4.0
What did you guys do about the electronic valve? Leave it unplugged? Or just plug it in to the 328i connector?
      01-03-2014, 05:47 PM   #17
TurboM
TurboM's Avatar
The 335i muffler has the exact same valve/plug.
      01-03-2014, 10:28 PM   #18
slmdgee
Usofstance
Drives: 328I 6SPD
plugged.
      01-07-2014, 04:05 AM   #19
speedyvk
Drives: Ford ST 2.5, 2013 F30 320i
Will this fit on 320i models? I don't see why not tbh. Can safe a lot this way..
      01-07-2014, 09:39 AM   #20
slmdgee
Usofstance
Drives: 328I 6SPD
yes its all the same lol!
      01-07-2014, 01:22 PM   #21
TurboM
TurboM's Avatar
I believe the piping size on the 320i is a bit smaller but positioning should be the same. You will also need to figure out a different solution for the bumper as I don't believe you can replace the small diffuser section like you can for the M-Sport lines.
      01-07-2014, 02:18 PM   #22
whitebeast1
sounds great, but how much is it because of the afe down pipe?
