BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Replace DRL bulb?
      12-15-2012, 10:08 PM   #45
Casualvic
Drives: 328i xdrive
Retrofit set will be sooo expensive.... I have halogen and want to upgrade with hid 6000k kit to include led on every other bulb... But want every color to mach up
      12-31-2012, 09:31 AM   #46
cronek
Drives: '12 F31 320d
http://store.ijdmtoy.com/BMW-F30-328...24w-sku-2f.htm
anyone tried these yet? They're quite cheap but in the pics it looks like the light output is significantly less than the original bulb...
      01-02-2013, 02:40 PM   #47
Graucho
Drives: 2012 BMW 328i F30
Originally Posted by Graucho View Post
I have them as parking light LED's.... NOT the DRL's.
The DRL's are 24W PW24W bulbs that I still can't find...
I found them... here is a video
      01-11-2013, 07:04 AM   #48
nybimmer91
Drives: 320i
does it really matter the light output on DRL? Its more for aesthetics no?...
      06-07-2013, 07:52 AM   #49
Roj_cookie
Drives: 320d ED
Bulbs for day running
Can I buy such bulb (blue tint) from Halfords?
      06-25-2013, 05:57 PM   #50
v1k1ng01
v1k1ng01's Avatar
Drives: 2013 335i M-sport
iJDMtoy has the best mod for LED DRL that I know of. If didn't opt for the xenon's I would do this mod.
      07-02-2013, 07:22 PM   #51
lt2334
Drives: 128i
This company makes an 18 led version of this bulb now. Does anyone know if it is closer to the stock halogen bulb in terms of brightness?
      07-03-2013, 02:32 AM   #52
Stiunit
Stiunit's Avatar
23
Drives: 2020 M340I
iJDMtoy are a little to blue for my liking. I would like something more white if possible
      07-04-2013, 10:13 PM   #53
lt2334
Drives: 128i
Is there any company producing a bulb closer to the white spectrum?
      09-05-2013, 12:59 AM   #54
F30 Epal
Drives: F30 320i
Just replaced my stock halogen DRL with ijdmtoy's pw24w:
Happy with the result!
My Instagram
Alpine White '14 BMW 320i 6-Speed MT: GSR Tuned, H&R Sport Springs, Injen CAI, Borla catback exhaust, ER FMIC/Chargepipe/Downpipe, VMR V810 wheels
      09-05-2013, 03:39 PM   #55
Deacon
Drives: 2012 BMW 328i Sportline
I did this same replacement right after getting my car - worked great for 2 weeks then multiple times daily the error codes were displayed that I had a light out. I could turn the light switch to make the DRL's go off and the error message would go away then when switched back the error came back - I did end up returning the bulbs since I was within my 30 day window and they refunded me my $30..
Was hoping another option would surface
Anyone????
2012 Black Sapphire Metallic 328i Sportline | Technology | Premium | Heated Seats
      09-05-2013, 04:20 PM   #56
TheTradingJD
Drives: 2013 F30 328i Xdrive
Mine fell out into the light because of the stupid prongs. Hit a bump and the light fell out of the socket. Getting the thing out of the light housing unit (not sure what it's called but inside the glass) was terrible.
      09-05-2013, 09:14 PM   #57
F30 Epal
Drives: F30 320i
That sounds scary! How were you able to get the thing out?
My Instagram
      09-06-2013, 04:53 PM   #58
v1k1ng01
v1k1ng01's Avatar
iJDMTOY.com has an 18 SMD LED option for $34. I don't recommend trying their 8 SMD option though.
      09-20-2013, 10:19 AM   #59
TheTradingJD
it was terrible, had to use one of those metal things that you squeeze on the top and a little claw opens on the bottom to grab things. It's normally used to pick up things you drop in your sink drain. Forgot what it's called, it's a long metal flexible tube with a hidden claw that comes out of the tube when you push/squeeze the top. Scratched some of the plastic on the inside, but what else can you do? I was very upset to say the least.
      09-20-2013, 10:20 AM   #60
TheTradingJD
check out my reply above.
      09-22-2013, 02:15 PM   #61
Syang3
Drives: 2013 F30 328i xDrive
Odd how there isn't a better replacement out yet, it's almost 2014.
      07-02-2016, 06:09 PM   #62
CazuaLLUK
Drives: 2014 335i Black F30 M Sport
Any UK store sell and fit the pw24w?
      07-02-2016, 06:28 PM   #63
elusive
elusive's Avatar
192
Drives: 2015 F30
http://www.horizonleds.co.uk/index.p...h&search=pw24w
They have a sale right now too.
      07-03-2016, 08:05 AM   #64
kuuzu
Drives: E82 125i MSport
All you need is a pw24w bulb as stated by everyone else. It's your choice completely as to what bulb you go for, but there are tons on eBay (UK at least)
I've replaced all the bulbs on my F30 Halogen.
This is the pw24w, which DOES give error code, but can be coded out.
http://www.ebay.co.uk/itm/1317637491...%3AMEBIDX%3AIT
Parking Lights can also be replaced with LED - I believe there is a thread on this somewhere.
And both high/low beam use H7, which I have Philips Diamond Vision for.
I'll try and get some pics whenever its dark.
      07-06-2016, 12:14 PM   #65
CazuaLLUK
Just picked up 2 from that ebay listing, how long you reckon they will last? Also how did you code out the error?
Also regarding the H7's, would be great to see pictures and also same with these. How long do you think they will last?
      07-08-2016, 07:19 AM   #66
kuuzu
I couldn't say how long they last - I've had mine for a couple weeks is all. There is a post somewhere here on the forums which I followed.
You'll need to get yourself a cable (check DIY section)
The H7 are fantastic, although I believe they've stopped producing Diamond Vision I think. I believe they were renamed to extreme vision or something along those lines. I managed to find a seller (opie oils) which sold Diamond Vision though.
I had them on my old fiesta (also H7) which lasted me a year before I changed car, but the difference in brightness while driving at night and white colour is brilliant.
I've replaced both dipped beam and high beam with these!
