10-22-2015, 12:19 PM | #1 |
Rep 61
I have a F30 with hi fi system that I upgraded to bav sound speakers. I am wondering if there is anyway to install two tweeters in the back door, with a filter of course. If there is I am thinking of buying the bav sound tweeters. Has anyone done this before? Is it possible? Please share your thoughts or DIY. Thanks.
10-22-2015, 03:57 PM | #2 | |
Rep 390
Best,
Charlie 2013 328i MSport Estoril Blue, 6spd MT, Premium, Tech & Drivers Assist +, Bavsound Stage One/Ghost, Bimmertech Amp |
10-22-2015, 08:22 PM | #3 |
Rep 346
Hi, if you open the rear door panel, you can see the tweeter outline. You need to buy an original tweeter bracket that goes into the stock location. The tricky part is to open a hole to the exact size. I have done this professionally at an installer here. The installer used a silicone glue to hold the tweeter bracket in place as we don't have special factory silicone type "rivets". I have no idea if the Bavsound tweeters fit into the original tweeter brackets as I did a HK upgrade.
10-22-2015, 08:30 PM | #4 |
Rep 346
I forgot to mention that you will need tweeter covers for the HK tweeters. I bought HK covers for the whole car so the part numbers are:
1. 5142 7 316 863 left side tweeter bracket 2. 5142 7 316 864 right side tweeter bracket 3. 5142 7 281 459 HK rear tweeter covers Pls verify the part numbers as I took it off the Stockist invoice. |
10-22-2015, 09:22 PM | #5 | |
Rep 61
How to wire it up? Does anyone know how to do this using bavsound speakers and tweeter? |
10-23-2015, 02:56 AM | #6 | ||
Rep 826
Drives: 2017 C43 AMG
2014 X5 xDrive50i Mineral White | DinanTronics Stage 1 | Vossen HC3
10-23-2015, 02:58 AM | #7 |
Rep 826
also tweeters in the back don't really do anything. if you really want to improve your sound setup get a pair of better mids and tweeters for your front doors and underseat sub with bimmertech amp. that'll do you much more justice than going great through the hassle of adding tweeters to your rear doors.
10-26-2015, 09:43 AM | #8 | |
Rep 61
Thanks. |
10-29-2015, 11:43 PM | #9 |
Rep 826
if by brightness you're referring to the highs you should be able to tune that via amp.
11-20-2015, 03:54 AM | #10 | |
Rep 1,035
oh man... i don't know how i missed this thread. I've been wanting to do this for awhile. I had a long discussion with Bavsound over this.
Here's where i'm at with my status:
When i look at the stock tweeter mounts for the front door panels, they are somehow "fused" or "welded" into the door panel when you look at it from inside. Its really well done as far as being integrated into the door panel, not sure how the process is done, but i doubt by DIY'ing someone will be able to get near that perfection. I wish they would just sell the door panel with the tweeter mounts installed as a separate part number, but i haven't been able to locate that yet. Quote:
11-20-2015, 04:01 AM | #11 | |
Rep 1,035
Just a fair warning though that from what Bavsound says, the OE amp for Hi-Fi only outputs half the power to the rears compared to the fronts. So putting tweeters in the rears may not have as much effect if you are still using the OEM amp. Since i have an upgraded amp that puts out 100W to the front and equally puts out 100W to the rears, it will be waaaayy more noticeable. Right now, the rears are really dull compared to my fronts. I want to equalize that a bit. And its not just more highs. The tweeters in the fronts are huge/powerful. It will make a difference in the back as far as output. |
11-20-2015, 08:30 PM | #12 | |
Rep 346
I am very excited as my stock set up is from a base setup with no amp and hence no harness. So I am waiting earnestly for my Bimmertech amp, main harness and amp bracket. Since I don't have center speakers, I am going to cut a hole to install the center channel and have purchased the HK center speaker cover. Then in mid Dec, I would have received the Bavsound underseat ghost subs ordered long time go. |
11-20-2015, 08:37 PM | #13 | |
Rep 1,035
11-20-2015, 08:37 PM | #14 |
Rep 346
When i look at the stock tweeter mounts for the front door panels, they are somehow "fused" or "welded" into the door panel when you look at it from inside. Its really well done as far as being integrated into the door panel, not sure how the process is done, but i doubt by DIY'ing someone will be able to get near that perfection. I wish they would just sell the door panel with the tweeter mounts installed as a separate part number, but i haven't been able to locate that yet.[/QUOTE]
Mine was done so well that you can't tell from outside that the tweeters were added later. The trick is to take out bit by bit and match the tweeter holders as you go along so as not to take out too much material. If you can find the correct tool with varying diameter, it will help but my installer did not have the tool and they first drilled as big as they could then use a NT cutter/blade to slowly remove bit by bit using the rear tweeter template as a guide. |
11-20-2015, 11:37 PM | #15 | |
Rep 346
11-20-2015, 11:42 PM | #16 |
Rep 1,035
awesome! that takes care of 99% of my concerns doing things like this only one time doesn't give you the practice needed to get things perfect. its nice to know you can hide your mistakes...
So once the bracket is pushed through the hole, it can secured just with some glue? Is this silicone glue like JB Weld / Quik Weld? or something different... All Bavsound speakers are designed to be direct drop-in replacements for BMW OE speakers so it should fit OEM brackets fine. EDIT: Btw... HK tweeters and Hi-Fi tweeters size should be same right? Last edited by squidlyboy; 11-21-2015 at 12:23 AM.. |
11-21-2015, 10:30 AM | #17 |
Rep 3,969
This is generally a bad idea if the sole purpose is to improve the sound for the driver and passenger seats only. First of all, adding tweeters in the rear will not take away "harshness" from the front. En contrere, it will add more harshness. Also, and most importantly, it will mess up the staging for the front seats by "pulling" the sound stage back towards the rear. In fact, there should be no need for rear speakers at all if the front stage is set-up properly.
There are only two reasons to have rear speakers: 1. You really really care about the sound for your rear seat passengers, and you are willing to sacrifice the sound in front to do so. 2. You listen to EDM music which is not recorded with a soundstage, and you want to be able to "blast" the music throughout the car and be in the middle of it so to speak, like in a dance club. If you care about reproducing "normal" (non EDM type) music the way it was recorded, you want to eliminate the rear speakers and focus on the front stage only.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
11-21-2015, 03:52 PM | #18 | |
Rep 61
06-19-2017, 03:42 PM | #19 |
Rep 120
Guys, please help me out, I found door trims with HK in my color on ebay for a reasonable price. Are there holes needed for tweeter installations in my door or how do they fix? Bolt to the trim? Anyone got pictures, maybe? Thanks in advance!
Honda Accord -> Subaru STi -> E93 -> F30 + F15 -> F30 -> F31 LCI -> G31
06-19-2017, 04:08 PM | #20 | |
Rep 16,065
