BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > [DIY] Remote start using Arduino
      12-30-2021, 06:48 AM   #23
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by AlbertoSONIC View Post
Nope, you have to completely tear down the key and solder wires on the actual key's board. The battery has to be connected to the project's board. The arduino will take care of powering the key's board using the battery. (using a relay to connect it)
OK, thanks
it is necessary as even that there have contact of the battery as indicated in the photo?
      12-30-2021, 07:38 AM   #24
AlbertoSONIC
Drives: 318d F30 LCI
OK, thanks
Nope, you don't have to connect those things, as they'll touch together when you rebuild the key.
      12-30-2021, 07:55 AM   #25
david51
david51's Avatar
France
538
Drives: bmw M3 F80
ok thank you very much alberto for your help
      01-01-2022, 11:01 AM   #26
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Hello,
Is it normal that the relays heat up a lot?
when i plug my plug into my box my bmw demare directly is this normal?
the relay indicator lights always remain on even with the ignition off?
      01-01-2022, 11:04 AM   #27
AlbertoSONIC
Hello,
I don't remember the relays heating up a lot..
What do you mean with the second question?
      01-01-2022, 11:24 AM   #28
david51
david51's Avatar
France
538
Drives: bmw M3 F80
I'm talking about the socket that feeds my box
      01-02-2022, 07:00 AM   #29
BeamerAR15
Drives: F30
Have you checked after 10 min. , when the car goes to sleep ?
      01-02-2022, 07:16 AM   #30
AlbertoSONIC
No that's not supposed to happen. All relay lights should light up only when the relay gets closed. What happens if you run the start sequence? Do they stay on or some light turns off?
      01-02-2022, 09:16 AM   #31
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Yes
after 10 min it remains on and the speedometer also remains on
      01-02-2022, 09:17 AM   #32
david51
david51's Avatar
France
538
Drives: bmw M3 F80
the boot sequence does not work
      01-02-2022, 09:23 AM   #33
AlbertoSONIC
Ok so all relays are receiving 5v, which is wrong. Is the wiring correct? If you look at the schematic, you can see that pin 1-6 of the relay board are directly connected to D2-D7 pins on the arduino. Is that the same in your wiring?
      01-02-2022, 09:36 AM   #34
david51
david51's Avatar
France
538
Drives: bmw M3 F80
yes I did the same
      01-02-2022, 09:49 AM   #35
david51
david51's Avatar
France
538
Drives: bmw M3 F80
the only difference with your connection
is that I took the power and the mass on the odometer.
and the k-can2 on the idrive wheel
      01-02-2022, 09:52 AM   #36
AlbertoSONIC
Just to make sure, have you programmed the arduino with latest code?
      01-02-2022, 09:57 AM   #37
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Can I do it remotely with ultraviewer?
I may have done the manipulation badly since I'm a novice with arduiro
      01-02-2022, 05:36 PM   #38
david51
david51's Avatar
France
538
Drives: bmw M3 F80
I always have the relays which remain on which heats the power supply and the relays.
is this due to an HS relay problem?
is the power supply supplying the relays and the nano card at the same time?
here are my connections
      01-03-2022, 01:37 AM   #39
AlbertoSONIC
Is the power supply set to output 5V?
      01-03-2022, 09:02 AM   #40
david51
david51's Avatar
France
538
Drives: bmw M3 F80
good news the relays are no longer lit
on the other hand output of the power supply I only have 3.38V
it is not possible to adjust the voltage? or must I buy another model ?
      01-03-2022, 06:38 PM   #41
AlbertoSONIC
The power supply has a gold screw on a blue component on it. If you turn that screw, you can change the output.
DISCONNECT EVERYTHING FROM THE POWER SUPPLY WHEN YOU ADJUST IT!!!
You risk to set the output too high and fry some components! (like the arduino)
Remove it from the rest, set it to 5v and reconnect everything
      01-04-2022, 07:40 AM   #42
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Thank you alberto
I tested the power board alone and the output is 5V as soon as I connect it to the relays and the arduino nano board the output goes down to 3.38V.
is this normal?
      01-04-2022, 04:50 PM   #43
david51
david51's Avatar
France
538
Drives: bmw M3 F80
I received my new power supply which is set to 5V at the output but unfortunately it still does not work
      01-04-2022, 04:54 PM   #44
AlbertoSONIC
Does the same thing happen when connected to the car 12V?
f30, remote, remote start
