03-12-2014, 10:03 PM | #155 | |
Rep 376
03-12-2014, 10:13 PM | #156 |
Rep 286
Cool. Thanks for that information. That makes sense. I dont think there is any new FEM MAX/HIGH available. Just the hardware revisions as D5, D6, D7.1 and D7.4 according to etk.
When you took the car to dealer for programming, did you put back the factory FA? If so did you have SVT targets updated on VCM so the modules get registered on VCM? Thanks again. Vithy |
03-12-2014, 10:54 PM | #157 | |
Rep 376
Not sure what you mean by the rest. I'm not a coding expert. When they reprogrammed my car, they did so using the options I added as if they could not tell they were added after. This did reset the extra coding that I did to turn off the auto level sensors so the error popped up after they reprogrammed. I told them I did not have time for them to diagnose the error and took my car home. They did try calibrating the sensors, which they didn't say failed, but said the error remained. |
03-12-2014, 11:22 PM | #158 |
Rep 286
Ok, so when you got the car back from programming they wrote back the original VO to the car?
I have a theory, where you would update not just your VO, but also your VCM (main ECU) with whatever additional ECU's you have added and write that back to the VCM. So when you take back your car, they will load the SVT (ECU's) from VCM. |
03-13-2014, 08:09 PM | #159 | |
Rep 376
Not sure what you mean by the rest. I didn't add any ECUs, just option codes. Again I am not an expert just saying what I know. I cant go into any more detail than this. |
03-14-2014, 04:17 PM | #161 |
Rep 54
I did it in a F20 with fem low, because, fem low does not support shutter remote (bi xenon).
in a F30, it is actually supported, fem is mid version with shutter remote i ordered a ICM high, in order to get ride sensor working, i will keep you informed. |
03-15-2014, 10:44 AM | #162 |
Rep 286
mougwai, Do you have the part numbers for the FEM low you have and the FEM mid? I have been looking at etk, and I only saw Hardware revisions on them. Such as D5, D6, D7.1 and D7.4. Very curious to find out.
Thanks |
03-15-2014, 04:48 PM | #163 |
Rep 54
04-17-2014, 03:13 PM | #164 |
Rep 10
Greetings! about the work of automatic leveling headlights. I do not have accurate information, but we at xenon retrofit on f20/f30 further change the headlamp switch to the appropriate 3,4,7,8. maybe the problem is really in it?
04-19-2014, 02:37 PM | #165 |
Rep 10
today did retrofit headlights on f20, just say that everything works (flap bi xenon work), all exactly the same as on the F30. after installing the lights, headlights required driver initialization, I did it with "BMW Rheingold" (replacement insta \ d). after reading the error appeared "mismatch control unit headlights." (as I wrote the post above, it is necessary to change this unit). I rationalized scheme DoNi to save time and contacts and will buy only big Clem and rubber seal.
04-19-2014, 03:34 PM | #166 |
Rep 54
good news, I replaced my xenon (522) by the dynamic version(524)... and dynamic headlight work as expected, xenon light turn when turning steering wheel: fog light works too while driving with slow speed.
There is no error on Idrive coded normaly. In my last retrofit with normal xenon 522, i got only the problem the height headlight ajustement... with 524 the problem still there: ICM error is not able to manage the height headlight ajustement: i am working on it, maybe ICM is the problem... Don't forget, i replaced my fem by a fem max, and added ride sensor (front and rear) that's why AHL work as aspected. |
04-19-2014, 04:19 PM | #167 |
Rep 10
backlight turns fog light can be encoded on a not adaptive xenon (and even halogen), provided if there is a light sensor. backlight will switch control unit light "auto".
Adaptive Headlights (fog light) FEM | 3062 | MAPPING_abbiegel_L_output | nsw_l FEM | 3062 | MAPPING_abbiegel_R_output | nsw_r FEM | 3066 | KL_ENABLE_LI | KL_Ein FEM | 3066 | KL_ENABLE_RE | KL_Ein FEM | 3073 | C_BLC_ENA | F30enable FEM | 3073 | C_CLC_ENA | F30enable |
04-19-2014, 04:39 PM | #168 | |
Rep 376
I am trying some coding tonight to see if I can get the autoleveling sensors working and will report back later. EDIT: Maybe I am misunderstanding you, are you saying you are not getting an autoleveling error at all with your latest retrofit on an F30? Last edited by kapkanimd; 04-19-2014 at 05:27 PM.. |
04-19-2014, 05:28 PM | #169 | ||
Rep 54
Do you have any error on Idrive ? So, now, we need a solution to get headlight vertical ajustement working, and retrofit will be done 100% |
04-19-2014, 05:37 PM | #170 |
Rep 54
04-21-2014, 09:32 AM | #171 |
Rep 54
04-21-2014, 10:27 AM | #172 |
Rep 376
Hey guys, I think the calibration is not my issue. I just ran INPA and found that one of my sensors is not functioning or reading correctly. It is different then the results mougwai originally came up with before he calibrated his. Please see the image and help me determine which sensor it is so I can try and figure out what is wrong. Thanks in advance.
I am also not saying that calibration with ISTA is not required, I actually took it to the dealer before who tried calibrating it so maybe they did so, but my sensor was still bad at that time. However, given the results of this test, it looks like it is readying properly at the ICM level, but that one sensor is not reading at the FEM... Or does the 0.00 reading mean it is not getting signal? Not sure what to make of it. EDIT: I have found that VL is for the front sensor, and HL is for the rear (V = Vor (In front) and H = Hinter (behind)). So I am having an issue with my rear sensor, however I cannot tell if it is the sensor itself or the wiring from the sensor to the ICM. Can someone help me figure this out? Last edited by kapkanimd; 04-21-2014 at 10:38 AM.. |
04-21-2014, 10:31 AM | #173 | |
Rep 10
I have not set the height sensors. but today coded block icm, and I had errors height sensor (error code 480116, 48006F, 480069) incorrect voltage height sensors front and rear, and no agreement made sensors. I just D90D16 error (control panel light is the incorrect model) So what to do coding options icm VO 522 (xenon lights) and 524 (adaptive lights (if adaptive headlights)). So, I can not control the position corrector through insta \ d, although this can be done without height sensors (or with faulty sensors, I did have a friend at f30 with the sensor disconnected). I am increasingly convinced that we need a control panel lights without a wheel height adjustment .. I do not know whether it is possible in this forum to spread links to the program, but if anyone need "rheingold bmw" (replacement insta \ d) I can give the link to a working version for personal messages. Last edited by Belinskii; 04-21-2014 at 10:42 AM.. |
04-21-2014, 10:41 AM | #174 | |
Rep 10
04-21-2014, 10:44 AM | #175 |
Rep 376
04-21-2014, 10:54 AM | #176 | ||
Rep 10
*Output voltage at the output of the sensor failure voltage: max. 2% *Output voltage at the output of the sensor wire breakage at the gnd: min 98% Quote:
