07-05-2021, 05:22 PM | #1894 |
Rep 303
07-06-2021, 01:18 AM | #1895 |
Rep 30
I just installed KW v2 coilovers i love how they feel the car is driving great. having slight rubbing in the inside of the fender, on a bump or uneven road,,, need help with what tires to go with
19x9 +35 245/40r19 19x10 +35 275/35r19 |
07-06-2021, 08:52 AM | #1896 | |
Rep 235
I would run some camber and make those fit, it doesn't look like you would need much |
kern4174454.50 |
07-06-2021, 09:00 PM | #1897 | |
Rep 381
How do you adjust damping in the rear shocks without removing them? I just installed KW V2 on my 2017 340i. I put all 4 damps on setting 11 or 11 clicks. I’m still trying to adjust tide height and need to drive the car a bit to get everything to settle, then alignment. |
07-07-2021, 04:57 AM | #1898 |
Rep 32
Hi Guys
I have a dilemma and if any wheel experts live here, maybe you'd be up for a challenge. I think I need someone who totally understands wheels offsets and specifically 3 piece configurations. My current wheels, which are Work VSXX in the following configuration: Front 8.5J x 20 ET32 A Disk (OEM brake clearance) 59mm or 2.5" Lip Rear 10J x 20 ET 38 (the wheels are ET48 but using 10mm spacers to make it ET38) O Disk (Deep Rim) 72mm or 3" Lip The Problem with the rears is that with ET48 and O Disk the caliper was fouling the backside of the wheel, so I had to space it. I'm running -2.4 Camber on the rear and front is OEM. My Dilemma (someone please help me!): I don't feel that the wheel has enough lip so wanted to go for 72mm/3" Lip front and 84mm/3.5" Lip rear (pictures of my current setup are attached with the narrower Lips). The wheels are also being replaced under warranty due to large paint issues (flaking and bubbling), which is allowing me to change the width, offset and colour, to get them right. So with that all in mind I want to widen/reconfigure the wheels to the following: Work will only make the wheels in certain configurations: Front 9J x 20 ET26 A Disk (72mm Lip) - which will mean more poke by 12.4mm Rear 10.5J ET 36 A Disk (84mm Lip) - which will mean more poke by 12.4mm I'm concerned that these won't fit, and will stick out of the arch too much, can someone, anyone shed any light on this at all? I don't like running spacers if I can help it but I don't see any way of getting the fitment right as these are 3 piece, the faces of the wheels won't move that much, its the barrels and lips that do (widen) if I'm understanding this correctly. There are two other options here... 1. Stick with my current setup and same offsets (don't like them as they are) 2. Use the chart above to obtain higher offsets and adjust the wheels with small spacers. HELP! I'm totally at my wits end! |
Sedan_Clan25169.50 |
07-07-2021, 08:32 AM | #1899 | |
Rep 381
I think you are considering too little of OS. It is easier to push the wheel out then it is in. I know a spacer is not ideal but id play it a bit more safe then so aggressive. Unless you are running a pretty small tire and a bunch of camber? |
07-07-2021, 08:41 AM | #1900 |
Rep 381
There is only so much room you can realistically go before things are out of range.
Example: a friend of mine ordered 18x12 wheels with 5” of lip for his 69 camaro. The OS was so bad that he has to narrow the rear 1.5” more than he thought and relocate his new suspension so much that the geometry of handling was greatly affected. Car was built for auto cross but changing that much in the suspension made it pointless. He now has 2 $1100 garage fixtures. Lol! |
07-07-2021, 09:23 AM | #1901 |
Rep 381
07-07-2021, 01:18 PM | #1902 | |
Rep 235
07-07-2021, 01:27 PM | #1903 | |
Rep 235
07-10-2021, 04:40 AM | #1905 | ||
Rep 30
07-12-2021, 09:49 PM | #1906 |
Rep 381
That’s a bunch of work I wish I had known prior. Just going to take more time to dial in I guess. Currently I have all 4 struts set at 11. I still need to adjust height and see how that feels. Then off to the alignment shop.
07-18-2021, 06:49 PM | #1907 |
Rep 381
Ok, so I found that all I needed to do after all was unbolt the strut from the top and then I can press the strut down to make adjustments to the damper. I set everything to 12 clicks and it rides great. Just need to take the car to the alignment.
07-19-2021, 04:24 AM | #1908 |
Rep 17
08-02-2021, 10:15 AM | #1910 |
Rep 235
Well after going through this thread at least 3 full times I’ve finally got my set up about 90% done besides alignment. I want to give a big shoutout to everyone I messaged on here and Instagram that helped me out, this community is awesome.
Here is a quick teaser before I get more pics from the wrap shop, this is the last time it will look like this Follow my build on IG @ flex_f30 Last edited by j2nicee; 08-02-2021 at 01:23 PM.. |
08-14-2021, 10:18 AM | #1913 |
Rep 18
prepping for wheels.
airlift 3p spl flca godspeed rear -7 rear & -3 front still need spl tension rods for more front camber can't add more rear because of stock wheel specs :/ |
aggressive, f30, low, slammed, stance |
