BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > CHALLENGE - F30 335 - HFC and Catless Downpipes - Now Released! - Pics inside -
Closed Thread
      08-16-2013, 08:38 AM   #155
Hunter399
Hunter399's Avatar
323
Drives: F90M5
Originally Posted by GTM_Challenge View Post
I haven't had anyone use the HFC with the power pack yet. Most of our customers have been using the Burger tuner that I have talked to.
I might be the first to try this
      08-16-2013, 08:39 AM   #156
boomn29
boomn29's Avatar
Drives: 2012 BMW 335i
I'm on the waiting list for both!
Challenge DP (prepaid) and BMW Power Pack (waiting).
2012 F30 BMW 335i
8sp; Red; Sport, 20x9f; 20x10r (wearing 245/275's) Bronze Forgeline DE3C's, M-PPK, Challenge HFC-DP.
Winter Setup: 18x8 Black Enkei's with Blizzaks!
      08-16-2013, 10:56 AM   #157
GTM_Challenge
GTM_Challenge's Avatar
Drives: E46 M3, E90 M3
Your DP should be picked up from the fab shop Monday looks like along with a bunch of others for stock
      08-17-2013, 01:36 PM   #158
Hunter399
Hunter399's Avatar
323
Drives: F90M5
I ordered the DP and already have the Power Pack and BMW performance exhaust. Should have it installed within the next week or so hoopefully
      08-17-2013, 06:25 PM   #159
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
Cool - let us know your before and after thoughts once you get it installed.
      08-18-2013, 01:57 PM   #160
boomn29
boomn29's Avatar
Very good news.
I also was notified Friday my BMW power pack (I've got a 2012) is in. It'll be installed Wed. Can't wait. Hopefully the DP gets here shortly and I can give a combined review along with video.
2012 F30 BMW 335i
      08-18-2013, 02:58 PM   #161
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Very good news.
You sure the DP will work with the PPK?
Might throw a cel...post here and let us know.
SOLD: 2012 335i Mineral Gray
      08-19-2013, 09:53 AM   #162
GTM_Challenge
Very good news.
Sweet. Cant wait to hear some feedback with that combo.
      08-19-2013, 12:38 PM   #163
tdizzle
Drives: 2017 F80 ZCP
Throwing a CEL will have nothing to do with PPK or other normal mods as far as I know. Chances are that it eventually will unless you have a mod that deletes the code.
There is a smaller chance (perhaps slightly) that you won't get one with a HFC, but I've heard those are popping up too. Your car is basically telling you the cat isn't working as well as it's supposed to stock. Which is obvious and the whole point to get more flow.
As far as 'will it work'? Well yea, it will work, it's giving you a freer flowing exhaust, it doesnt care that you turned up the boost. In fact, it allows you to turn up the boost more (safely anyway).
      08-27-2013, 02:53 PM   #164
boomn29
boomn29's Avatar
Very good news.
My early 2012 build F30 finally had it's BMW M-PPK installed last Wed at the dealer. Then on Sunday it got a Challenge DP (in my garage).
Because everything happened so close, I didn't have a lot of comparison time. I maybe put 30 miles on the car between the upgrades. I can say the Sport Displays were updated from a max range of 320/320 to 400/400 like others have stated. They pegged at 320/320 after the MPPK; and immediately after the DP install I spotted them ranging more towards 350hp. Further testing at WOT is def necessary, and I should try to hook up my GoPro to safely verify really. I also want to use it to get some exhaust audio. I can hear the cackle - lightly - in pretty much any gear off-throttle no matter if it's 5000 or 2500 rpms.
Overall, there's not a lot of increased sound inside or outside the cabin. There's probably 10% more when in the throttle, maybe more but nothing that's gonna turn heads. I've had cars in the past with full catless exhaust, so that's my measuring point! RPM's on this awesome 8sp trans make a difference too.
More to come. Hopefully audio/video whenever I have time.
2012 F30 BMW 335i
      08-27-2013, 03:06 PM   #165
DVC
DVC's Avatar
Drives: 335i
Awesome... this sounds like a great combo. I am planning to do the same (along with the MPE)
      08-28-2013, 11:56 PM   #166
t335xi
Drives: 2013 335xi Sedan Sprt Line ppk
I've never heard of a cop actually inspecting a car to the detail of cat or not. Are you saying after this the car is throwing out clouds of black smoke or that its pegging us fornoise violations?
      08-29-2013, 10:00 AM   #167
tdizzle
Who are you referring to in regard to your comment?
Even catless, you shouldn't see smoke unless something is terribly wrong with your engine as far as I know. Just a slight sweet smell.
A DP should make the exhaust a bit louder/throatier, but nothing crazy. Not even as much as a loud aftermarket exhaust.
IMO the biggest concern people would have is emissions inspections and possible check engine lights. You can get around the CEL with a tune that auto clears it, but not much you can do about emissions if they really get in there and test it.
      08-29-2013, 10:51 AM   #168
DVC
DVC's Avatar
Drives: 335i
In the absence of a tune that auto-deletes CEL codes, is there another way to reset them on an as-needed basis? If the HFC downpipe might just cause them on rare occasion, than I'd still be interested in it if there's some sort of easy solution to just plug something into the OBDII and delete when necessary.
      08-29-2013, 11:06 AM   #169
tdizzle
I know they've had them for previous models, but not sure about the F30. You could probably get a code reader, similar to what comes with flash tunes, that would do the trick. But then again, they're not cheap and you'd get far more bang for your buck buying a JB4 that you can use to boost engine output and read/delete codes.
      08-29-2013, 01:08 PM   #170
boomn29
boomn29's Avatar
Yes. Goto autozone and buy a code puller/reader. I did that years ago when I started modifying cars and it's worked on every vehicle I tried. I tossed the booklet, I just punch the # into the internet and it tells me what's up. It can also delete.
http://www.autozone.com/autozone/acc...eader/_/N-25iq
I think I paid like $70 back in 2007 or so. Looks like they are much fancier nowadays and in color! Much safer and easier than unplugging the battery to clear imo.
fwiw; I've been getting a P0030 code with my M-PPK & DP combo. I've cleared it twice but it's coming back thus far.
2012 F30 BMW 335i
      08-29-2013, 01:32 PM   #171
DVC
DVC's Avatar
Drives: 335i
Cool - thanks!
This model seems like it covers all the bases, and is only $35 shipped...
Are there any other specific models that anyone can recommend?
      08-29-2013, 02:21 PM   #172
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
Before I got the JB stage 2, I used the Torque app on my phone. The app was like $2 and I had to buy a obdII bluetooth dongle for like $20ish.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      08-29-2013, 02:26 PM   #173
tdizzle
Catted or Cattless DP?
I think Challenge has been saying the HFC DPs haven't been throwing the CEL, so just wondering.
I think the tune will auto clear that particular code, but yea if you don't care for a tune and can find a cheap way to clear the annoying light then I guess that is the way to go (unless it pops up all the time, then it could be an annoyance)
      08-29-2013, 05:52 PM   #174
GTM_Challenge
So far, stock ecu cars, with our HFC downpipe have not been throwing CEL's. Nathans car above is the first with the power pack ecu flash etc that has run our HFC. Likely the ECU has changed some setting for the o2 sensor sensitivity
We are working with Nathan to see if maybe a spacer can fix the CEL on the power pack ecu flash
      08-29-2013, 07:13 PM   #175
DVC
DVC's Avatar
Drives: 335i
Mike - thanks for the tip on the Torque app...I found it in the Android Play store too. Seems like a better way to go than a dedicated hardware unit (cheaper and more features : ) Do you recommend any particular Bluetooth dongle?
tdizz - yeah, I'm not interested in anything that would throw a cel all the time, or even often. It seems like the hfc downpipe only throws them one in a while, if at all, so that seems livable.
I am going with the mppk, so I probably wouldn't be interested in other aftermarket tunes anytime soon.
Challenge - seems like you guys are on point with standing by your product and working to ensure the best experience for your customers...this is why I plan to buy from you. Thanks.
      08-29-2013, 08:14 PM   #176
mikew2069
mikew2069's Avatar
413
I just bought a cheap blue one on eBay or amazon for $20ish and its worked great. What's really nice is you can log runs and you can also plug it in to any car. Cool app for so cheap. Definitely opt to pay the $2-$5 for the real app rather than the free version....
I've bought a couple of things from challenge and they've always been great. I sometimes wish I woulda went catless but I love my hfc dp so it's all good!
BM3/H&R/Borla
Closed Thread
