07-22-2014, 12:06 AM | #1 | |||
Rep 5
F30 LED Foglights Coding
I've seen a few different people post which sections to code to eliminate any errors and flickering with LED foglights but they seem to each be a little different. Can anybody post what they coded and if it worked successfully?
For example, I've seen: Quote:
They each seem to have one or two codes that the other ones are missing. Which one(s) have you guys tried? Thanks! |
07-23-2014, 09:30 PM | #2 |
Rep 3
I am wondering the EXACT same thing and am having the exact same thoughts as you. Have you tried any of these combinations yet, yourself?
Thanks! |
07-24-2014, 01:38 AM | #3 |
Rep 931
I have replaced the H8 35W fog light with a cree led h8 lamps
No error found ! The coding is not necessary if the leds are canbus and high power.
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
07-24-2014, 06:38 PM | #4 | |
Rep 5
Thanks guys. This is what worked for me:
07-25-2014, 04:37 PM | #5 |
Rep 5
True, you could use a canbus error decoder (basically a resistor) but then you would have to find a place to mount it without worrying about it melting down. With coding, you can plug in any H8 LED bulb and have it work without any errors or flickering.
07-27-2014, 02:07 AM | #6 |
Rep 931
07-28-2014, 05:27 AM | #7 | |
Rep 84
Fluffy Russian СaT
