03-15-2018, 08:52 PM | #1 |
Rep 1,503
B58 Downpipe O2 Spacer on Stock Car
Can those who are running a catless dp (VRSF, ER, VM, etc) on a stock car share what kind of O2 spacer has worked for them?
I'm hoping to consolidate a sample size large enough so that people could make an better decision between L and straight spacers. Also, it would be awesome if people could post pics of what worked and what has not worked! Here are examples of the shapes: L - https://www.amazon.com/gp/product/B0...=AZZQLCSVQ753J Straight - https://www.ebay.com/itm/Blox-Racing...-/301947480064
FBO M235i r
F80 M3 Last edited by ocN55; 03-15-2018 at 10:07 PM.. |
03-15-2018, 10:00 PM | #5 |
Rep 965
Drives: 2016 F36 435x MSport
Dont forget about J spacers lol
https://www.amazon.com/Vibrant-11619.../dp/B00AQ7972O I have one of these because i heard great things about their compatibility from the Porche community, unfortunately never got a chance to try it.
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
ocN55559.50 |
03-16-2018, 06:32 AM | #6 |
Cheapskate
4447
Rep 4,993
I don't have a downpipe on this car, but a straight spacer worked on my previous car. I don't know the brand since I got it from a friend for free. the CEL didn't come back for 20k+ miles.
However the J/L spacers are the best option if you want to be sure it works the first time. it is better at keeping the CEL away and easier to fit since a straight spacer makes the 02 sensor stick out really far and may be close to hitting the body of the car or other components in the engine bay. Just don't go paying $50 for a billet etched carbon fiber blah blah blah spacer. They all do the same thing and can be had for $10 or less. |
03-16-2018, 06:42 AM | #7 |
Rep 579
I still run the blox racing one you posted. over 20k miles now and no CEL.
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T |
03-16-2018, 04:29 PM | #8 |
Rep 115,980
There are a few people out there running spacers with success.. I was actually surprised they worked and worked for an extended period of time without a CEL.
Mike |
03-19-2018, 07:02 AM | #9 |
Cheapskate
4447
Rep 4,993
Not sure how hard it would be, but it would be cool if the aftermarket companies integrated a J into the 02 sensor bungs on the downpipe to make it full proof and we don't have to buy an extra component to make it work. even if the welded the J inside the downpipe so that exhaust gases flowed past it, it would probably work and no obvious modification from the outside.
SCRPN8.00 |
03-19-2018, 10:16 PM | #10 |
Rep 235
Mine is an L shaped and two straight spacers stacked on the long end - don't do this. O2 will read nothing instead of something and you'll get a CEL anyway. Run either one straight spacer or two stacked together but I think L is too long.
Current - 2018 M2 | VRSF Chargepipe | VRSF Catless Downpipe | Dinan Catback | Turner Motorsports Intake
Previous - 2016 340i M-Sport | AWE Tuning Touring Edition Exhaust w/ Non-Resonated Performance Mid Pipe | Agency Power Intake | Active Autowerke Activ-8 | VRSF Catless Downpipe |
03-21-2018, 01:50 AM | #12 | |
Rep 1,503
Could you explain what the 655% reading means though?
FBO M235i r
F80 M3 |
03-21-2018, 09:22 AM | #13 |
Love to Drive
197
Rep 602
If you have a OBD reader with the OBD Fusion app or similar you can check mode $06 under “monitors”... there you will be able to monitor secondary sensor performance among other things.
655% reading is what measures cat efficiency... 100 is min 655 max if you dip below 100 you get a cel right away... In order for the spacer to work consistently you want to be above 400ish |
03-21-2018, 10:25 PM | #14 | |
Rep 1,503
It looks like the spacer you're using has some adjustability. Do you mind sharing how you adjusted it?
FBO M235i r
F80 M3 |
03-22-2018, 09:28 AM | #15 |
Love to Drive
197
Rep 602
It is adjustable but I got it in the closest setting... this is perfect because I still keep a very low rich/lean delay without affecting catalyst efficiency readings which need to remain above 400...
I also have an 18 M3 with the S55 engine, it comes from the factory with high flow metal cats and it ranges around 400-500% but has secondary cats to take care of the rest. The B58 is pegged at 655% stock, which shows you just how restrictive the factory cat is since its actually ceramic, these tend to “clean” the air a wee bit more at the cost of flow and cat life span. As always YMMV. |
DocBlackhawk4.00 |
04-17-2018, 02:47 PM | #16 |
Rep 308
finally put downpipe back on car and swapped spacer with this one and so far after 300 miles no light. Normally would have had one or two pop up by now
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
04-17-2018, 02:59 PM | #17 |
Rep 210
I use the L shape one no CEL still ^^
Car List: 2000 328i E46 Steel Gray Metallic 5SPD MT- Sold 2016 340i F30 M Sport Mineral Gray Metallic 8SPD AUTO - Current |
04-19-2018, 12:25 AM | #19 |
Rep 145
Sorry if this is a dumb question, but what would cause the spacer to eventually give a CEL? I would assume if the life of the downpipe in the car WITH an O2 spacer, it should ultimately be showing a consistant cat efficiency percentage?
04-20-2018, 12:39 AM | #22 |
Rep 1,503
Assuming it's just OBD, it should be find
FBO M235i r
F80 M3 |
