10-20-2015, 09:45 AM | #25 |
Rep 477
10-20-2015, 10:49 AM | #26 |
I want to drive a Zamboni
1129
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
Took the car to dealer twice and problem remains, they had insert foam padding and rattle is still there.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
10-20-2015, 12:06 PM | #27 |
Rep 477
I took mine to the dealer also and they said they verified the issue. They said the bottom piece was not fitted correctly so they corrected it, road tested it, and it was gone. I had my doubts about this and lo and behold, the issue is still there. However, today I inserted a small microfiber rag into the space where maverick83 put the sponge, and, oh yes, the silence is like a Strauss waltz to my ears.
10-20-2015, 12:19 PM | #28 | |
1129
Rep 5,557
10-20-2015, 03:56 PM | #30 | |
Rep 294
10-20-2015, 04:19 PM | #31 |
Rep 477
10-20-2015, 06:39 PM | #32 |
Rep 3,659
Drives: 981 Cayman GTS
10-21-2015, 11:26 AM | #33 |
Rep 294
Its a neoprene type sponge you buy in strips with one adhesive side. Its usually used to seal windows and doors, on houses. The sponge will return to its original shape if compressed.
I have extended the steering wheel completely, applied the sponge on the spot I checked previously, then pushed it flat all the way after which I then returned the steering wheel to my preferred position. Done... |
10-21-2015, 04:04 PM | #34 | |
Rep 477
10-22-2015, 01:55 PM | #35 | ||
Rep 294
03-13-2016, 05:34 PM | #36 |
1129
Rep 5,557
Took mine in last Wednesday and shop foreman can reproduced the buzz noise, he mentioned it came from steering column and got to wait until the repair is completed and will keep you posted.
12-01-2016, 08:36 AM | #39 |
Rep 477
Yeah, my dealer couldn't fix this either but I used Maverick's method and now I have 2 pieces of foam tape stuffed in between the column and the dash on both sides. It works, but jeez you'd think BMW could do a little redesign to fix this (and all their other common rattles).
