06-26-2013, 07:47 PM | #3917 |
Rep 40,779
They did not back the Integration Step, and in fact they programmed the car with the latest. The car shipped with ISTA/P 2.48.3, F020-12-11-505 (released Nov 2012), and they updated it to ISTA/P 2.49.4, F020-13-03-503 (released Mar 2013).
06-27-2013, 03:07 AM | #3918 |
Rep 3
hi all
i have f30 320d date 24 april 2013 year where i can get programs to coding my f30? my mail pps2003@bk.ru |
06-27-2013, 07:00 AM | #3920 |
Rep 27
fuel pump / fuel pressure sensor fault are not the single case of F30 in Hong Kong, some F30 in HK got these issues already.
06-27-2013, 08:29 AM | #3922 |
Rep 18
Hello ! It turned out to be map sensor...replaced and all is well. They said the F30 has quite a few problems...radiator leaking, hoses breaking, air con not cold..various sensors etc.
06-27-2013, 10:09 AM | #3923 |
Rep 1,976
Drives: 2020 G20 320i M Sport
06-27-2013, 11:01 AM | #3924 |
Rep 124
I have the psdzdata 49.4 but don't have the password to unlock it.
Previously shawn sent me the 49.3 link.. which i altered to get the 49.4. I tried unlocking using the 49.3 password but doesn't work.. LOL Btw, anyone here can tell me how i can activate Traffic info? I previously have it but after dealer updated my ilevel, it stop working. Icon is there but no info. |
06-27-2013, 01:24 PM | #3925 | |
Rep 40,779
06-27-2013, 01:37 PM | #3926 | |||
Rep 40,779
PM sent.
06-27-2013, 04:32 PM | #3928 |
Rep 173
I just took delivery of my car today and tried coding but I can't get "Activate FA" to work. I've tried it a few times and it starts then the pop-up disappears. Active isn't displayed next to FA and when I try to code my changes I get the you need to activate an FA message. There no other error messages.
Any thoughts to this? edit: just ran through it again and got it working. i right clicked and activated fa first.. then did the rest of the instructions. for some reason if i try editing the code first trying to activate fa doesn't seem to want to work. in any case just glad i got it working.
'13 F30 335xi • white/black • m-sport
06-29-2013, 12:43 PM | #3929 |
Rep 664
Drives: 2013 BMW 335i
I've been busy with school for the past few months been away from the forums for a while. Haven't had time to tinker with any of the coding. Last time I checked I need to purchase a token to code the car if my dealer updates it. I plan on bringing the car in about a week or two now that I have more time. Can someone link me to the newest version of eys, and pzdata? Also is a token still required to be purchased or there is a bypass to that now? Thanks!!!
06-29-2013, 03:26 PM | #3930 | |
Rep 40,779
06-30-2013, 10:05 AM | #3931 |
Rep 5
I've already got 3.18_4 and 47.5, but I'm sure there's a later version out there :-) A couple of F10 520D M-Sports to code, and I think I need a newer PSDZ dataset.... Cheers! |
06-30-2013, 01:02 PM | #3933 |
Rep 31
Drives: 2013 328xi
Is there a cheat sheet for codes for a 2013 f30
06-30-2013, 01:44 PM | #3934 |
Rep 2
Shawn,
Following the advice you gave me on another forum, I verified my I-Step based on (F020-12-11-502) requires at least psdzdata of 48.0. Given that, I've only been able to find 49.4. Can I combine these versions some how? I just need a few files, I'm not sure it works that way. Or if you have a link to 48.0 I'll try that. Thanks, Tyler (at) tylergraves(.com) |
06-30-2013, 04:50 PM | #3935 | |
Rep 40,779
06-30-2013, 05:26 PM | #3936 | |
Rep 139
I've changed the salapa element to 6NK. No BT streaming option still. In the FDL, I did see some items which say ENT_BTAS also...when I try to change items, it says failed to sign FDL I've got the new nav Last edited by endless402; 06-30-2013 at 06:04 PM.. |
06-30-2013, 07:41 PM | #3937 | |
Rep 40,779
The reason you can't FDL Code is either you do not have a working .EST Token, or you did not install yours properly.
06-30-2013, 08:21 PM | #3938 | |
Rep 2
I was able to eliminate the legal warnings (so annoying, there are two since i have the backup sensors) and I was able to set the stop/start to remember last. I'll mess around with more later, but those were my big pain points. T |
