12-25-2019, 08:15 PM | #133 |
Rep 2,655
This happened to me a few days ago for the first time. Happened for a few minutes and then went away and hasn't happened since. Not sure what the deal is.
12-25-2019, 09:36 PM | #134 |
Rep 10,473
12-26-2019, 09:06 AM | #135 |
Rep 2,655
Great, lol. I guess I should anticipate a visit to the dealer. Hopefully they can swap the HU inder CPO.
12-26-2019, 09:40 AM | #136 |
Rep 10,473
01-03-2020, 08:20 AM | #137 | |
Rep 83
What you describe is another type of failure. What I described is an interruption. Same error message, different limitations. Neither of us is wrong, but I also leave it to you to make wrong assumptions and interpretations as well as unnecessary repetitions after this. |
01-03-2020, 08:34 AM | #138 | ||
Rep 10,473
Lots of luck finding your spin in BMW Documentation instead of your assumptions. Again, BMW lists the 3 items causing the condition. Yours is not among them. |
10-05-2020, 07:31 PM | #141 |
Rep 4
Solved the No signal issue on the HU
Seen the "No Signal" on the HU and been looking around for a solution but could not find straight forward answer. Yes there is the Technical bulletin but it seems that a low voltage will give you the same 'No signal'. interestingly i know the HU was good because when putting in reverse the backup camera will display properly then back to Drive and No signal will appear after breif flickering!
I have a retrofit backup camera and did some coding with Esys but all worked perfectly with no issue for the past 3 years. I know my original battery is due for a replacement but still, it is going strong. What solved the issue for me what to recharge the battery overnight. not driven much lately but that solved the problem so wanted to share. hope this helps someone Cheers 2014 F30 |
06-11-2021, 01:54 PM | #142 | |
Rep 5
06-14-2021, 12:35 PM | #143 |
Rep 3
Thank you so much for your post! I've been struggling with the exact same issue on a 2016 F30 NBT EVO 8.8". I've had several indications that it's time to replace the battery (it's still the original) - I so hope it will solve my "no signal" problem! I'll post an update afterwards.
08-03-2021, 06:41 AM | #144 |
Rep 51
Drives: 2013 328i xDrive, 2018 X3 M40i
Check cable
I also have gotten this issue and resolved it by replacing the screen cable. Seems the connectors are very sensitive. It started when I went on a trip for a few weeks in Memphis, the humidity must have caused the initial issue.
11-04-2021, 09:35 AM | #145 |
Rep 3
After some advice please. I have a BMW 2 series with an old screen. Wanted to change it out for one of the newer flat screens.Whilst I managed to purchase on I got the,"No Signal" message when it was connected. Is this because it is a resolution issue?
I apologise if I may come across as being naive in thinking that you could just swap screens. Any help appreciated. |
12-20-2023, 11:02 AM | #146 |
Rep 1
Hi all!
This happened to me for the first time a few days ago. I also think it might be related to undervoltage. Long rant: It was cold outside, but only -2C (or maybe a -5C max at night) and I drove all day on Autobahn, with plenty of braking and coasting (so at least that blue indicator had plenty of time to tell me the battery is charging). Also, the battery is old and couple of years ago I saw the "low battery" message on the instrument cluster when I didn't drove for a week in winter, but not since then. So... 2 days before the error I bought (and used for a couple of hours while driving) a 66W super fast charger. The error appeared while I stopped in a parking lot, so the first thing was to removed the charger. After an off/on from the start button, the message went away and everything seemed normal. I drove some 100km more, and at night I went to a gas station. While driving the error appeared again. I noticed the dashcam kept turning off and it said the card was not formatted. I thought that was weird. I also had the dashcam's charger connected to the cig lighter outlet from the glove compartment, but it's really low wattage. I disconnected the charger and 2000km and 3 days later no more "No signal" message. F34 2013, made for Germany, NBT HU by harman updated with the latest firmware I could find on bmw's website, with an aftermarket backup cam connected to it. I read the errors and this is related: "E1C440 The fault is entered when the control unit is next started after a reset." So it just tell me it made a reset, not the cause of the error. But I also get other errors that might be somehow related. "8011F9 The fault is an internal fault of the electric auxiliary heater.... The fault code entry does not describe a fault in the heater circuit, but documents the fact that the heater output of the electric auxiliary heater was restricted due to an insufficiently charged 12 V vehicle electrical system." "801A4C - SINE: undervoltage detected in internal voltage supply. When a fault is present the DWA operation will malfunction. Triggering the acoustic alarm is not ensured." This one I think it's because of the battery that's inside the alarm module. I also thought I could plug as many devices in the outlets and the worst thing would be a blown fuse, but maybe not. I'll take the car to service in the future and I'll post here the results, maybe it will help others. |
12-21-2023, 09:09 PM | #147 | |
Rep 1,582
Starting a new thread may get you faster response.
