BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > What is this engine noise?
proTUNING Freaks
      03-15-2024, 02:12 PM   #1
germanzaddillac
Drives: BMW 328i
Hi. I was driving my car last night and when I was about a mile from getting home, I started hearing this whirring noise coming from the engine. The strange thing is that the noise was present at around 30 mph but at about 5 mph above or below that, it went away. The engine was fully warmed up and at operating temperature.
I tried to replicate the issue today, but wasn't able to. The timing chain seems tight and isn't whining when I rev to 3,000 RPM or higher, so I don't think that's the issue. The serpentine belt does not have any visible tears and is tight and centered. The radiator fan spins freely without rubbing.
The car is a 2013 328i with original timing chain. 64,000 miles on the odo. Thanks for your help with this.
Link to audio file: https://www.dropbox.com/scl/fo/6iipb...c857lzwvg&dl=0
      03-15-2024, 03:16 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Sounds like the beginning of 'Sympathy for the Devil'. Probably something rattling.
If you haven't had your timing chain tensioner replaced you need to do it, like yesterday. That's the cause of timing chain failure.
      03-16-2024, 03:24 PM   #3
germanzaddillac
Drives: BMW 328i
Ha! It does sound a bit like that. Thanks for looking into this.
This car has been a money pit, so I'm holding off on doing the timing chain tensioner replacement until I know I want to keep the car long term. That's good advice, though.
The sound came back after a while and it seems that it has something to do with the power steering. When I have the steering wheel turned to the left and am driving at around 30 mph, I get the sound. Turning the wheel to the right doesn't cause the sound. I'll keep investigating.
      03-16-2024, 10:20 PM   #4
Billfitz
Billfitz's Avatar
The steering rack of that vintage was a known problem. Google it.
      03-17-2024, 04:33 PM   #5
germanzaddillac
Drives: BMW 328i
Thanks. I'll see if that's the issue.
engine, n20, noise, whirring
