BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > Multiple misfires 2015 550i
      03-18-2024, 03:16 PM   #1
f10nate
f10nate's Avatar
Drives: 550i
2015 550i  [0.00]
I got a 15 n63tu an I’m throwing a p0030 and a p0036 bank 1 and I’m getting multiple misfires on the scan tool it’s saying dme 2 misfire cyl 5 7 and 8 this all started right after I put the cats back on and I thought the cats where clogged so I put the downpipes back on and it’s still misfiring. I don’t see o2s on bank one causing misfires this bad, any ideas
      03-18-2024, 08:33 PM   #2
S EyeLand
Drives: F90 M5C
You prob damaged an O2 sensors if you were messing with the cats, happened to me half the time I went catless.
      03-20-2024, 11:47 AM   #3
f10nate
f10nate's Avatar
Drives: 550i
2015 550i  [0.00]
Yeah I had the cats in and out least 3 times have you seen misfires from that though?
      03-25-2024, 08:29 AM   #4
RockCrusher
Drives: BMW 2023 ZB M2 6-speed
Address the O2 sensor codes. They point to a bad #1 sensor and a bad #2 sensor (#1 before the converter, #2 after the converter).
Handle the new sensors with extreme care. Do not use anti-seize. This can foul the sensor tips. (When my cars (Porsche cars) needed new O2 sensors I used factory sensors. They came with a light application of some clear grease on the threads.)
With the error codes gone then see if misfires are still present.
With exhaust system work an exhaust leak is always a real possibility which could account for the misfires.
