04-14-2018, 01:14 AM | #46 |
Rep 1,348
Link for DV and map sensor pm me thanks!
2k15 335i Msport xdrive 6spd
04-14-2018, 01:17 AM | #47 | |
Rep 1,348
04-14-2018, 06:50 AM | #48 | ||
Rep 1,827
Just logging some data to send to Nic for any tweaking that might need to be done. It is stupid fast, purely butt dyno, but I'm also hoping to get on a dyno soon and maybe hit the local track for some official 1/4mi ETs.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
04-14-2018, 07:53 AM | #49 | |
Rep 1,348
Well I see two maps I will be requesting! Ethanol and 93 octane! Keep up the logs guys these are great times for the development of this tune. Glad I was patient.
BMW DIY Guy3109.50 |
04-17-2018, 06:35 PM | #50 |
Rep 191,433
04-18-2018, 02:14 PM | #51 |
Rep 603
you missed a few weeks of having more fun driving your car!
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
04-18-2018, 05:33 PM | #52 |
Rep 1,348
Well hopefully this Saturday I can put on the FMIC and Springs and have the 3.5bar map sensor and tune uploaded on Friday. The DV valve upgrade gives me shivers!
05-10-2018, 11:08 AM | #53 |
Rep 1,348
Vote in this pol if you have an AA tune! select "other" then post your tune
http://f87.bimmerpost.com/forums/sho...7#post23173797
TMac335i68.00 |
05-10-2018, 11:10 AM | #54 | |
335i F30
68
Rep 252
13' F30 335i Mineral White Metallic
Sport Package | 19" Rotiform SPF | BC Coilovers Coral Red Interior | H/K Package Active Autowerke Flash Tune, FMIC, Exhaust | BMS Intake | VRSF DP | VRSF CP |
06-03-2020, 01:25 PM | #56 |
Rep 603
Guys
I'm confused. Having the AA stage 1 flash for about 2 years, I just additionally flashed the 8HP with xHP Stage 2 a few days ago. Even when xHP config is set to use 2nd gear from a standstill in Comfort/Sport mode, the car seems to always drive off in 1st gear. (Dashboard also displays 1st gear (D1) when in standstill. ) So I flashed xHP back to "stock" just keeping the gear info the dashboard. Even then, D1 is shown in standstill Comfort mode. So now I am confused and wondering, if AA tune has an impact on that?! I didn't pay any attention to that before the xHP flash. Does AA flash use gear 1 even in Comfort mode? Cheers (by the way, I'm very pleased with the AA tune so far.)
06-03-2020, 03:37 PM | #57 | |
Rep 1,827
06-04-2020, 04:17 AM | #58 | |
Rep 603
Just flashed the xHP with the option to show the gear in use in the Dashboard (so showing i.e. "D1" instead of just "D") I also recognized, that when I'm in standstill comfort mode and D, and I then shift from "comfort" to "sport" mode, that the car moves a bit into brakes. Just like, when it would shift into a lower gear. Display also shows "D1" then when in sport mode (which is as expected). I will try to find out, at what speed/rpm the first shifting happens when starting at standstill "D1" in comfort mode. Either in total 6 or 7 shifting points to end. Will see. Plain counting Just thought someone would no right away if AA flash always takes first gear from standstill even in comfort D.
06-04-2020, 11:04 AM | #59 |
Rep 211
An email to Nic at AA should get you a definitive answer.
Mineral Gray - Active Autowerke Stage 2 - MPerformance Suspension - VRSF CP - CTS Turbo IC - Catted Fabspeed - Akrapovic - HRE FF15
04-07-2024, 12:18 PM | #60 |
Rep 161
Sounds a lot like my tune with DME Tuning, before it started to pull timing (probably could have held it if I ran E15). Felt like a monster at any speed, yet super cool and composed. On the highway, the car felt like an asteroid, effortlessly gliding, with ZERO resistance - just with the tip of the toe. Unfortunately, after reflashing the car never felt the same, and I was never convinced I being given the same map I had originally - perhaps DME Tuning tuned it down, in fear of liability. I think AA tune may be different because it addresses part-throttle and valve timing, which is how they achieve such enhancements in daily driving.
19' 330i G20 E85 Custom Tuned
100-200km/h 11.76 seconds (Racebox GPS) Full bolt-ons (stock turbo/stock engine) |
04-07-2024, 05:23 PM | #61 | |
1303
Rep 3,552
2017 m240i xDrive 10.67@132.32mph w/bm3
04-07-2024, 08:09 PM | #62 |
Rep 161
I am actually responding because I just bought an AA tune..Heard a lot of good things about the company. I'll do a post with my review.
04-07-2024, 08:31 PM | #63 |
1303
Rep 3,552
With bootmod3 and mhd nowadays nobody much will care tbh.
04-08-2024, 10:26 AM | #64 |
Rep 191,433
its a solid tune, looking forward for your review
04-08-2024, 11:17 AM | #65 |
Rep 211
I've had an AA tune for several years, stage 1 then stage 2. Installed before bootmod3 and mhd became so popular. No issues whatsoever and no real reason to change.
04-08-2024, 11:59 AM | #66 |
1303
Rep 3,552
Yeah but there is no reason to do all of that as someone buying a new tune with better more customizable options available...
