BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N20 GFB DV+ installed without moving or touching the turbo! +quick tutorial
      04-18-2018, 04:36 PM   #89
Drogon F30
Drogon F30's Avatar
Drives: 2012 BMW
That motor is gonna blow
      04-18-2018, 05:21 PM   #90
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Still waiting for you to explain why. Despite an overwhelming out of evidence and support that says it is normal and not harmful, you still disagree, yet won't explain why it's harmful. All it does is make you seem like you have no evidence that it's harmful.
For background for those not informed, this guy believes that the DV+ flutter is not normal. When asked for proof, he failed to provide any and resorted to personal attacks and then blocked me.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit
      04-18-2018, 05:30 PM   #91
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Here's more proof for you. Dzenan runs PTF. Is he wrong, too?
View post on imgur.com
      04-18-2018, 07:44 PM   #92
ilivas
Drives: 428
Even full blow compressor surge isn’t THAT bad. There are many people that don’t run bovs
Also, it doesn’t affect the motor. Just the turbo
      04-18-2018, 07:49 PM   #93
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Even if he comes back to comment, which I doubt he will, don't even try, dude. At least with you and I, we came to a respective standing. This guy? Not a hell in chance. He's the type of guy who hurls personal attacks when he loses, rather than admit he's wrong. I wouldn't trust him with a lawnmower.
But exactly. At most we're talking about killing the turbo. Shows how much he knows. Oh well. You cannot educate everyone I suppose.
      04-18-2018, 10:47 PM   #94
ilivas
Drives: 428
On a good note, My DV+ came in today.
      04-18-2018, 11:02 PM   #95
Mid_Night_F20
Mid_Night_F20's Avatar
23
Drives: 125iM N20
Just the thread I've been looking for, got a GFB DV+ sitting in the box waiting and waiting for the stocker to fail (cbf fitting it)
N20, EWG, Full M package, 19" x 8.5/9.5, JB4, Catless DP, Custom 3" exhaust, Upgrade intercooler with metal piping, drop in K&N, Snow Performance Stage 2 kit
      04-19-2018, 08:35 AM   #96
sspade
sspade's Avatar
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Mine arrived as well.
Assuming everyone is planning to install with the spring for the first go around, correct?
Was reading the paper it came with that describes the differences.
Would hate to have to take everything apart again to remove spring.
Also... picked up the following from harbor freight. Is there anything else I may need?
Diegov209164.50
      04-19-2018, 09:07 AM   #97
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
So long as those are thin enough to get in there, you could do without loosening the manifold of course.
As for the spring, that is up to you and everyone else. All it comes down to is: Do you want or care about the occasional flutter when you release low boost buildup? If yes, install. If no, don't install. Simple as that. I personally think it sounds cool and even better when I'm going through the hills and release it high gear, low RPM/low throttle. If you don't like it or find it tacky, you can remove the spring but at that point, why install at all? If your stock DV is torn, then I could see why; otherwise, you're wasting your time because the DV+ will operate the same as the stock one. The DV+ is there to provide a stiffer spring and only one hole vs 6-7(Whichever number it is. Might be 8).
Sorry to rant, just surprised that people (not you, SSpade) are reluctant to do their own research and prove flutter harmful, despite the overwhelming amount of evidence and support from engineers.
      04-19-2018, 09:09 AM   #98
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
For the three of you installing their DV+ this week or soon-ish, just ensure that one, it's authentic of course. Two, when you are driving, ensure that you aren't getting any leaks or flutter while you are still on the throttle or after high boost release (I'm talking WOT, raising to 6k RPM and release)
      04-19-2018, 10:58 AM   #99
Diegov209
Drives: 540i Xdrive
Good old harbor freight im going to get me some of those because I did mine with small allen wrenches lol.
BunkerJ1032.00
      04-19-2018, 11:46 AM   #100
ilivas
Drives: 428
I assume the spring is to prevent boost leak at higher boost.
      04-19-2018, 12:02 PM   #101
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Yes and also to ensure the lowest amount of boost escapes on shifting. Once you install it, you'll notice your shifts kick a little harder.
      04-19-2018, 01:34 PM   #102
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
sort of off topic, but I noticed that my shifts are actually quite harsh and I have done nothing to my transmission, it's a stock non 2TB unit and I don't have a DV+. in sport mode on the transmission, especially at the drag strip, it feels like an SMG single clutch almost. it really kicks like a bitch. if I can I'll try to get a video of it if I can, probably gonna be hard to show on video though. is this normal? do your guys shifts give you any sort of kick?
      04-19-2018, 02:25 PM   #103
ilivas
Drives: 428
I don’t think the car has an active rev match so it might explain why it shifts hard. Mine is kind of rough in sport mode.
      04-19-2018, 04:18 PM   #104
rjd_F30
rjd_F30's Avatar
idk, it seems on manual downshifts it sort of rev matches . that would only apply to downshifts though no? I'm talking about a kick on WOT upshifts.
      04-19-2018, 04:57 PM   #105
ilivas
Drives: 428
True. Mine really isn’t that rough. Maybe it’s time for a fluid change
      04-19-2018, 05:03 PM   #106
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Not sure TBH. I was a non-2TB originally and just coded it in. I forget what life was like before that... Lol. I mean, you could try a drain-n-fill on the tranny and see. You could also just code in 2TB and see if it helps.
      04-19-2018, 05:24 PM   #107
rjd_F30
rjd_F30's Avatar
both good suggestions, thank you. I have to take it in for service soon and I'll ask to have them check it out and do a fluid change.
      04-19-2018, 10:38 PM   #108
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Drives: '13 328i Msport 6MT
My friend took my 5mm key to work to grind down. I should be set for the install on Monday
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes
Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
BunkerJ1032.00
      04-20-2018, 08:43 AM   #109
sspade
sspade's Avatar
What about the 4mm ? Not necessary to grind that one?
Im going to see if my work has a bench grinder I can use. The harbor freight set I have looks quite fat...
      04-20-2018, 09:29 AM   #110
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
If not, it's time to find a patch of concrete. Lol.
