08-03-2015, 03:38 PM | #9043 |
Rep 40,752
What version of E-Sys Launcher are you using, and is E-Sys Launcher Car Series set to F31?
08-03-2015, 04:39 PM | #9044 |
yunior
18
Rep 23
Drives: 2018 430i Xdiver (f36)
08-03-2015, 05:31 PM | #9046 |
Rep 40,752
You cannot send or receive PM's yet. Send me one when you can.
08-03-2015, 07:09 PM | #9047 |
FNG
Rep 35
08-03-2015, 09:03 PM | #9048 |
Rep 40,752
The link is constant, and TokenMaster updates the version periodically, so that doesn't answer my question.
If it is not 2.1.2. Build 63, I would update.
08-03-2015, 09:20 PM | #9049 | ||
Rep 1,035
I replaced my original REM with an older REM that had the right pins for PDC, but it seemed like it was a little _too_ old and ran into some issues. I then order a newer REM, but the dealership sent me an even newer one saying it the one i ordered is not available any more, and this one is the newest/latest. Appreciate any insight here |
08-03-2015, 09:21 PM | #9050 | |
Rep 40,752
08-03-2015, 11:59 PM | #9051 |
Rep 1,035
08-04-2015, 12:05 AM | #9052 |
Rep 40,752
Yes. PM sent.
08-04-2015, 12:13 AM | #9053 |
Rep 1,035
PSA: Driver's seat - easy entry code
I googled around to see if this code is wide-spread yet, but it doesn't appear to be. Its pretty cool... your seat slides back automatically when you turn off your engine and open the door, allowing you easier exit without bumping into the steering wheel. And when you get in and turn on the engine, the seat automatically slides up, putting it into driving position. And if your steering wheel has a power tilt/lift, you can throw that into the mix as well.
Here's a video of someone demonstrating it (just the seat movement part of it)... bobbiedigital started a thread on it |
08-04-2015, 02:43 AM | #9054 | |
FNG
Rep 35
08-04-2015, 05:57 AM | #9055 |
Rep 109
I got an issue when I tried to code my F30 2013 328 for mirror auto folding feature. There is no ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN under 3110 PfExternalMirrorMaster in FEM_BODY module. I also couldn't change the status of ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN to aktiv because it was not in the dropdown edit box. I did it two years ago and it worked fine until the recent service in July. It seems that they changed something in PfExternalMirrorMaster when they reprogram my car ;-( Did any one experience the same issue?
08-04-2015, 06:52 AM | #9056 | |
Rep 40,752
http://f30.bimmerpost.com/forums/sho...postcount=8999 See if you can inject cafd_00000794.caf.014_040_121 and use it instead. Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on FEM_BODY => Click on "Detect CAF for SWE" => Select cafd_00000794.caf.014_040_121 => Select OK => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE. Then try FDL Coding it.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 08-04-2015 at 01:01 PM.. |
08-04-2015, 12:10 PM | #9057 |
Rep 77
Internet & Live gone after dealer upagrade
Hello, i have a f31 that came with:
609 612 614 615 616 676 698 6AA 6AB 6NF 6NL Its a Germany National Version but im portuguese. it goes to the BMW dealer and they upgrade the software were in Portugal. Since them i have lost all items on the connecteddrive menu. Only have Hotline(with a german phone number) , mobile care and service point. Can anyone help me how to get BMW LIVE, BMW ONLINE and Internet again? Kind Regards |
08-04-2015, 03:57 PM | #9058 |
FNG
Rep 35
It is in fact 2.1.2.63
08-04-2015, 04:22 PM | #9059 |
Rep 40,752
Judging by the fact that your FEM_BODY has cafd_00000794.caf.004_228_010, it's too old.
E-Sys Launcher CAFD Mapping is based on each ECU's highest CAFD version from the last Untrimmed version of PSdZData, which was 54.1. Since your FEM_BODY CAFD is much older, and the CAFD has undergone significant changes since your version, the Mapping is not correct for such an old CAFD. Cars with anything less <= to 54.1 on them should use regular E-Sys with 54.1 PSdZData, and not use E-Sys Launcher at all.
08-04-2015, 04:30 PM | #9060 | |
Rep 109
08-04-2015, 04:33 PM | #9061 | |
Rep 40,752
08-04-2015, 04:58 PM | #9062 | |
Rep 109
Can I switch back to 122 using the same steps? Is there any difference between two 122 showed by Detect CAF for SWE? Another maybe unrelated question: After reprogram by the recent service of my car, its engine auto on/off still can not remember the last user setting. Is it true that F30 firmware should be able to do it by default now? |
08-04-2015, 05:17 PM | #9063 | |
Rep 77
Ps: Sheridan I have code all the things I want except BMW online anda BMW live... thx |
08-04-2015, 05:37 PM | #9064 | |
Rep 40,752
I do not know what the default coding is for ASS function these days.
