BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > 2016 F30 Check Engine light - EVAP leak >0.5m
      06-26-2018, 09:59 AM   #1
igorbmwx6
igorbmwx6's Avatar
Drives: 2016 BMW 328i F30
Check engine light keeps coming back on, after I clear the fault. Fault code has to do with EVAP leak > 0.5m I have tried to replace fuel tank cap+seal and that did not resolve the issue.
exact fault message observed:
Fuel tank ventilation and purge air system, micro-leak: leakage greater than 0.5m
Any suggestions as to what to try replacing next? Is there a DIY write up for replacing these parts?
Leak sensor? Charcoal canister? Part#s for 2016 F30?
Any input on this would be greatly appreciated
      06-26-2018, 10:09 AM   #2
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
There have been a couple threads regarding this in past few months. Search the forum and they should pop up. If not, those who fixed this issue will possibly chime in eventually.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit
      06-26-2018, 10:21 AM   #3
igorbmwx6
igorbmwx6's Avatar
I tried searching for "evap micro leak" and did not find anything relative
      06-26-2018, 10:24 AM   #4
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Here is one I was thinking of: http://f30.bimmerpost.com/forums/sho...highlight=evap
      06-26-2018, 10:32 AM   #5
igorbmwx6
igorbmwx6's Avatar
After reading thread, everything in my case is leading to the NVLD.
Do you know part# for 2016 F30 328i NVLD? DIY? Where is it located? Any images / videos would be greatly appreciated
      06-26-2018, 10:38 AM   #6
igorbmwx6
igorbmwx6's Avatar
What is the suggested part# to replace?
      06-26-2018, 10:43 AM   #7
igorbmwx6
igorbmwx6's Avatar
Is this the most likely culprit?
      06-26-2018, 10:49 AM   #8
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
NVLD appears to be 16137448092 as indicated here: http://www.realoem.com/bmw/enUS/show...83#16137448092
For repairs, it seems you must remove the right tank cover: https://www.newtis.info/tisv2/a/en/f...oring/I4tKx7Mo
Then you can replace the NVLD: https://www.newtis.info/tisv2/a/en/f...oring/JLcN6TyU
Please see the note included in the above link that mentions: "Important!
When replacing the pressure switch, the dust filter must also always be replaced."
Link to replace dust filter for NVLD. Part # can be found on the same page of the RealOEM page linked above: https://www.newtis.info/tisv2/a/en/f...-pump/JLgQmkTh
Functional Description (Just good info IMO): https://www.newtis.info/tisv2/a/en/f...-nvld/GwJjhwAW
fe7565552.50
      06-26-2018, 11:18 AM   #9
igorbmwx6
igorbmwx6's Avatar
Thank you so much for all the details and links. Will reply back to this thread once parts are ordered and replacement DIY is completed. Hoping that this will solve my problem. Seems like it is a common problem for many F30 owners. Faulty (factory defective) NVLD
      06-26-2018, 10:35 PM   #10
igorbmwx6
igorbmwx6's Avatar
Purchased required replacement parts
Purchased required (with highest failure probability) parts for replacement job. Should be able to complete this DIY over the weekend. Additional information, images and instruction are on the way. Excited to get this issue resolved. Ended up costing $100 in total for both parts
      06-26-2018, 10:39 PM   #11
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Purchased required (with highest failure probability) parts for replacement job. Should be able to complete this DYI over the weekend. Additional information, images and instruction are on the way. Excited to get this issue resolved. Ended up costing $100 in total for both parts
Keep us updated!
      06-30-2018, 07:57 PM   #12
igorbmwx6
igorbmwx6's Avatar
DIY - images
Ended up being 30-minute DIY job. All components are located on the right (passenger) side of the car, closer to the middle. Once bottom cover is removed, all is exposed and can be clearly identified.
see images, feel free to ask any questions
      07-02-2018, 08:58 AM   #13
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
I'm assuming all is well now?
      07-02-2018, 09:45 AM   #14
igorbmwx6
igorbmwx6's Avatar
So far so good. Will write back if Check Engine light comes back on. Keeping fingers crossed, hoping that this issue is solved. Thank you so much for your help with this one.
BunkerJ1032.00
      07-02-2018, 11:14 AM   #15
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Anytime! Hoping this was the issue!
      07-14-2018, 11:02 PM   #16
igorbmwx6
igorbmwx6's Avatar
After three more tank re-fills no more check engine light. Fault is gone and has not come back. I have a very strong feeling that this was the issue.
A message to all forum members who have F30, check engine light with same fault code as I have mentioned at the beginning of my post, save yourself time and money. Buy a $35-$45 part, take 30 minutes of your time and replace it. 99.9% it is the root cause of your problem. Feel free to ask me any questions related to the DIY procedure.
BunkerJ1032.00
exE36M3487.50
      04-21-2019, 12:33 PM   #17
iifeainteasy
Drives: 328i f30
Effect fuel consumption
I got a p0440 code. Will the malfunction of this part cause my car to burn fuel more aggressively?
      09-13-2019, 11:30 AM   #18
moegd55
moegd55's Avatar
Drives: BMW F30 335i Msport
Where did you get your parts from for 100$ total?
F30 335i Mperformance |Pure turbo stage 2|Upgrade LPFP|BMS Intake|VRSF CP|CTS catless DP|CTS FMIC|KW v2|MHD PS2 tune| M titanium performance exhaust|Xhp stage 4|Xdelete
      08-17-2020, 03:02 PM   #19
itsrichierich
Moto Lover
itsrichierich's Avatar
187
Drives: '19 BMW S1000XR
Recently got this error code on my BM3 app. I think it's time I replace these parts as well!
      08-17-2020, 05:04 PM   #20
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
I've got the same problem. When the codes are translated from the original German they say the tank leakage module is not responding and there's no electrical contact with the tank module. This is covered by a 10 year 100,000 mile extended warranty. I'm going to replace the module myself, which runs around $40, as it's more trouble than it's worth for me to spend a day driving to and from my dealer and waiting the inevitable three hours for them to do a half hour job. The tube, which has on one end a filter, doesn't have to be changed, only the module.
      10-03-2020, 04:04 PM   #21
nyc_dude
nyc_dude's Avatar
Drives: 09 //M3 e90 Interlagos Blue
DIY is missing the vent pipe and dust filter replacement.
Note this is a 340i with a B58 engine, vs. a 335i with a N55 engine.
Cheers
      10-03-2020, 04:18 PM   #22
nyc_dude
nyc_dude's Avatar
Fuel Tank Breather Valve replacement...might cause a CEL. Super Easy.
This is a B58 engine model, so the N55 replacement might be different.
Massive labor on a E9X M3 for the same swap.
Cheers
2016, check engine, evap, f30, leak
