09-21-2015, 03:04 PM | #45 | |
Rep 20,651
It's very rare to be able to do this level of shit without some very senior cover. |
09-21-2015, 03:07 PM | #46 |
Rep 62
From the fact sheet:
Emissions were measured over 97 trips, totaling more than 140 hours of operation and 6,400 kilometers driven. Performance differences among the vehicles tested indicate that the technologies for real-world clean diesels already exist. Some of the tested vehicles, such as the BMW X5, had average emissions below Euro 6 emission limits, suggesting that the technologies to achieve that level of performance are available. So probably not a problem for BMW. |
09-21-2015, 03:39 PM | #47 |
Rep 25,112
Wait, just remembered! I was in Florida this year, exposed to those dangerous VAG emissions.
How do I join a class action lawsuit?
My car made front page of Bimmerpost
09-21-2015, 03:44 PM | #48 | |
Rep 15,858
The X5 results could depend on the after treatment system, SCR has been part of BMW's strategy particularly in the US market. We are not using the SCR system over here on most of BMW's EU6 compliant diesels. I wonder if this is where there is a bigger issue. The shadow definitely falls on EU6 vs. real world NOx levels. HighlandPete |
09-21-2015, 03:51 PM | #49 | |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
09-21-2015, 04:16 PM | #50 | |
Rep 19,982
And I say this not to be pedantic, but to point out that one could argue the same thing has happened here in the UK/Europe.
09-21-2015, 04:20 PM | #51 |
Rep 19,982
This whole thing goes back to 2009 cars, which means it's before Winterkorn's time as CEO. So it will be interesting to understand how high this issue was understood. Hard to believe that Piech himself (as an engineer himself through and through) didn't know that this was happening.
Or else it is actually a lower level issue with the engineers, perhaps put under a lot of pressure from senior management to achieve the targets, and just found a 'smart' way to do it... Going to be a fascinating story one way or another.
09-21-2015, 04:24 PM | #52 | |
Rep 20,651
Yes but it is a cross platform issue. So unless it's a common bit of kit (hardware/firmware/software), then it must have been known to VW and Audi management. What about Skoda and Seat? |
09-21-2015, 04:47 PM | #53 | |
Rep 15,858
Just been digging through some of my files and found a study/report by one of the key companies in exhaust after treatment, Corning Environmental Technologies. Study is looking at how NOx is lowered to comply with EU6 and the US Bin 5.
It tracks the NOx after treatment developments and makes very interesting reading about low loads and low engine rpm. It looks at early and late injection strategies and how the NOx formation regime is avoided with high levels of EGR that keep the flame cooler. But continues... Quote:
HighlandPete |
09-21-2015, 04:54 PM | #54 | ||
Rep 19,982
That the engines management systems are designed to work ideally for the tests and not elsewhere in the operating parameters?
09-21-2015, 05:28 PM | #55 | |
Rep 15,858
Say the ECU is reading light loads and interpreting to use one 'mode' or strategy, then as load increases it applies a different exhaust treatment 'mode' or strategy. You just can't use too high a ratio of EGR as load increases. Reading more of the same report it is clear higher loads do require more complex after treatments to control emissions. There has to be an explanation to how a vehicle can comply with EU6 under test conditions, but in real world driving emits NOx at much greater values. HighlandPete |
09-21-2015, 05:38 PM | #56 | ||
Rep 19,982
09-21-2015, 05:39 PM | #57 |
Rep 805
What I don't get is why don't they just make it a feature, ie a different map connected to an eco button, use that mode for the testing and leave consumers to choose which mode they want to use.
Or is there more to it? |
09-21-2015, 08:40 PM | #58 | |
YOLO
440
Rep 2,854
& then you had extra-Eco mode |
09-22-2015, 03:31 AM | #59 | |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
09-22-2015, 03:50 AM | #60 |
Rep 19,982
Or is it just like revising for a test when you pretty much know what the questions will be?
09-22-2015, 04:04 AM | #61 |
Fool
1857
Rep 3,542
The reason this probably went on so long is the U.S. emissions tests don't actually check emissions! They plug a computer into the OBD port and trust what the car is saying. This is one of the reasons OBD2 was mandated in 1997.
09-22-2015, 04:17 AM | #62 | |
Rep 15,858
The quote from the report I included, shows there is potential to meet emission levels quite easily under low load conditions, (compared to the whole engine scope). Not hard to imagine the content in the "think bubble" in engineer's heads, as they are designing to a test result. What is clear, any switching (deliberate or innovative) to meet the tests is viewed as a "defeat device" as it does appear to be a way around the full scope of emission ratings, otherwise we'd not be seeing VW where it now is. Was listening to a motor industry analyst this morning and he can't see (besides those involved inside VW) how others like BMW, Merc, etc., are not aware of this practice. He used the example of all makers tearing down each others cars, examining everything including software. I sense the plot thickens, I'm sure the European investigation will show flaws and loopholes in the way the tests are conducted (probably the system itself) and how far they are from reality. What has stood out to me, even with the earlier reports of cars failing EU6 emissions tests in the real world, it didn't appear to be taken seriously here in Europe. It seems it has taken the US EPA and others investigating this issue, to look for why and how. HighlandPete |
09-22-2015, 05:16 AM | #64 |
Rep 15,858
Just being announced that up to 11 million VW diesels could be under investigation, broadens the fiasco outside of the US.
HighlandPete |
09-22-2015, 05:19 AM | #65 |
Rep 6,065
