BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > 4GC - Tint issues, warnings, advice?
proTUNING Freaks
      11-05-2014, 10:20 AM   #1
jd_perspective
jd_perspective's Avatar
Drives: 2016 X3 35i M-Sport
Just ordered a 4GC and the first thing I must do is get it tinted, however I wanted to inquire on these cars since I'm new to BMW. Any known problems or things to watch out for when getting these cars tinted? I ask because I know these are frame-less windows and that means rubbing on the tint when the doors close. Also, I've had a car in the past that was known for scratching front window tint if you didn't put moleskin over the window guides. (learned that the hard way)
So just was curious if there is anything I should know... thanks!
2016 X3 35i M-Sport
2019 440i Coupe M-Sport - Retired
2018 330i Sedan M-Sport - Retired
2015 428i Gran Coupe M-Sport - Retired
Last edited by jd_perspective; 11-05-2014 at 10:21 AM.. Reason: formatting... gah!
      11-11-2014, 06:52 AM   #2
Jarviiiis
Panda F32
Jarviiiis's Avatar
28
Drives: 2015 F32 435i xDrive
I have a 2015 435i coupe and the tint shop had an issue with both the framless windows and the dot matrix at the edges of the window.
The frameless window made it so he had to sit in the car with the door closed so he could apply the bottom part of the tint, since every time you open the door the window adjusts down / up when you close it.
The dot-matrix isn't a problem proprietary to any particular make or model.. it is just difficult to deal with since there are small deviations in the texture window which makes it difficult for the film to stick.
I have heard of some instances where people will actually sand/grind the dot-matrix down to provide a smoother surface for the tint to adhere to.
      11-11-2014, 11:52 AM   #3
jd_perspective
Interesting... there must be a way to turn off the window roll-down. I'm guessing just a battery disconnect or something. I'll have to investigate!
2016 X3 35i M-Sport
      11-19-2014, 05:39 PM   #4
reddemon73
reddemon73's Avatar
Drives: 2014 BMW 435
There is a button you push on the side of the door to keep the window from coming down when the door is open. Most good tint shop should not have a problem with this. All frameless coupe has this option on the car, not just BMW
2014 435i M Sport //AW, CR//premium, tech, lightening pkgs//20% tint//full clear bra//ppk//blk grills//20" Vertini wheels//digital gauge//Apple Carplay//MPE with catted DP//VSRF charge pipe//Wagner FMIC//
      12-06-2014, 11:11 PM   #5
_Mbition
_Mbition's Avatar
Nigeria
106
Drives: E92 M3
While open, Push the door latch down. Tricks the door into thinking it's closed and rolls the window up..
PAST LOVES:: 2 E39's, 4 F30's, 1 E92 M, 1 F80 M, 1 F15 e, and an F56.
CURRENT:: 2ND E92 M3.
      12-06-2014, 11:17 PM   #6
Mike_L
Drives: 2015 335xi GT M-Sport MPPK
If you can't find the button to keep them up, just pull the fuse. Easier than disconnecting the battery and having to reinitialize everything.
      12-07-2014, 07:31 AM   #7
katsbimmer
Drives: 2010 e90 328i Msport
2010 328i LCI E90  [10.00]
2006 325i  [0.00]
Yup thats what my tint shop did...
AW 2010 E90 LCI
