05-19-2018, 01:42 PM | #1 |
Rep 61
Stock 435i Catback on 428i xdrive
Hi,
I'm picking up a 435i exhaust from another member, and he is selling the full catback. I know that others have swapped the muffler without issue, but has anyone swapped the whole catback out? I figure worst case I can just swap the mufflers. I don't have an m-sport, so I will be trimming the bumper to fit and putting quad tips on. We'll see what happens. Can someone educate me on the "plug"? I have read about it but I'm not sure I follow. Since this is a stock 435i exhaust will I need to decide if I want that plugged or unplugged permanently? I don't believe my car has any wiring for the plug. Please bear with my basic questions - I have never changed an exhaust on any of my vehicles. Thanks! |
05-22-2018, 07:43 AM | #3 |
Cheapskate
4445
Rep 4,993
The midpipes are a similar shape, so it will probably fit. But I can't say 100%. You'll just have to mate it up to the car and see if it all lines up. The only issue I see you might have is connecting it to your stock downpipe.
428i midpipe http://www.realoem.com/bmw/enUS/show...diagId=18_0986 435i midpipe http://www.realoem.com/bmw/enUS/show...diagId=18_0977 Regarding the plug, both the 428i and 435i have the same flapper. so if yours has the plug, then remove it from your stock exhaust and install it on the 435i exhaust and it'll work the same. Otherwise you don't need to do anything.
05-22-2018, 12:14 PM | #4 | |
Rep 61
If they have the same muffler and similar piping, what's the advantage of installing the 435 exhaust? The other threads that I had seen reported a change in exhaust pitch and sound. I am primarily doing it to wind up with quad tips and to have an exhaust that has a little more sound to it. |
05-22-2018, 12:15 PM | #5 | |
Cheapskate
4445
Rep 4,993
05-22-2018, 12:31 PM | #6 | ||
Rep 61
I'm a bit nervous about cutting the bumper, but I figure worst case I get an m sport one and I'm out a bit of money to have it painted and fitted. I don't think the 435 exhaust will line up with the stock cut out, so I'm hoping the exhaust shop can reroute the piping before the tips as needed, and get everything lined up nicely. |
05-22-2018, 05:54 PM | #7 |
Masterchief
354
Rep 1,003
The n55 exhaust has a dimple on the exhaust where you cut if you want to install the mperformance exhaust.
I'm guessing the n20 engines exhaust has the same dimple. If so, you should make your cut there and use the clamp to install.
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
05-22-2018, 05:57 PM | #8 | |
Rep 61
Is there really any advantage to running the mid pipe from the n55 or should I just swap the mufflers? Thinking now if they are basically the same part, what's the value add? |
05-22-2018, 06:05 PM | #9 | |
Masterchief
354
Rep 1,003
Also i wouldnt go as far as switching out the entire stock catback from a n55 and put it on the n20. I would only do the axelback muffler. There is probably minimal to no gains. Exhaust is all for sound and aesthetics. If you want performance from an exhaust mod, the downpipe will be the most beneficial. There are tons of people who have done the single to dual outlet exhaust conversion. Both exhausts should have the exhaust valve actuators as well.
Zopperman21.00 |
05-22-2018, 06:17 PM | #10 | ||
Rep 61
Thanks. That's very helpful - I'll see if I can find the dimple and cut it there. It would make it a lot easier to transport to the exhaust shop too. I'm not expecting much of a performance gain from this, really just trying to get quad tips and a little more sound. I just bought an intake but I think the downpipe will be next, or BM3. |
05-27-2018, 02:23 PM | #12 |
Rep 61
Small update for those interested.
I picked up the exhaust today, and I cut it between the center muffler and the rear muffler so that it would have less of a foot print. Figure I'm just going to have the shop weld it in place anyway, and worst case they can weld it back together. |
kern4174445.00 |
05-29-2018, 07:17 AM | #13 |
Cheapskate
4445
Rep 4,993
Should have told everyone it's a super exclusive off-road antenna system
