05-26-2018, 06:13 PM | #1 |
Rep 25
205 to 2TB - paddles help
Hi,
I did a VO code on my 2014 F30 and changed 205 to 2TB, works fine I read that i need to disable the paddle shifters now as i don't have them and it's likely throwing errors. I have read i need to do FDL coding and modify: SZL_LWS_03 > Variantencodierung 3000 > Lenkrad_Schaltpaddles = nicht_aktiv basically setting paddles option back to not active... I have searched my FEM_Body "tree" and don't have anything close to the above. Does anyone know what i'm doing wrong here? Thanks in advance! |
05-27-2018, 09:11 AM | #3 |
Rep 25
So this would mean the paddles are already disabled? I thought 2TB would enable that by default?
http://ibb.co/bHAOt8 ...it's a link to an image, not sure why i can't embed it in the page, the IMG tag doesn't work for me. Last edited by livemane; 05-27-2018 at 09:14 AM.. Reason: comment |
05-27-2018, 09:27 AM | #5 | |
Rep 25
You have to code new FA (as explains the pdf file attached above) in 4 ECUs : -EGS, -GWS, -Kombi, -ICM. So it's that simple? before i go back to the dealer just recode VO to 205? Thanks for the help |
05-27-2018, 09:37 AM | #6 |
Rep 53
Right, that indeed explains it. I believe it's not necessary to code GWS for 2TB, but FEM_BODY should be coded. In every cases the paddle shifters should be disabled if you don't have those (as is the case), in addition to throwing up errors having them coded will also cause "phantom" shifts for no reason.
And yes, if you want to revert the car back to the original when taking the car to the dealer you can simply revert 2TB with 205 and VO code FEM_BODY, ICM, KOMBI and EGS. |
05-27-2018, 09:51 AM | #7 | |
Rep 25
05-30-2018, 05:33 AM | #9 |
Rep 34
205, 2tb |
