04-16-2015, 09:37 PM | #1 |
Rep 1,961
Pic of the battery rail?
Thats a term I've never heard before, so could somebody tell me where exactly the battery rail is? Pic would be great. Can't disconnect the battery on the F34, so to install a JB4, Terry said to lock the car, wait 10 minutes and put tape over the battery rail.
04-19-2015, 10:31 AM | #4 |
Rep 1,961
04-19-2015, 11:22 PM | #5 |
Rep 467
should be a red plastic tab covering a metal clip under the hood for a jumper cable to attach to.
If you're looking into the engine bay under the hood it would be like the upper left quadrant if it's the same as what they did for n54. I'm not sure if that's different from the battery rail though. |
05-23-2017, 11:14 PM | #7 |
515
Rep 1,063
The battery rail is basically the exposed terminals on the positive post on the passenger side under the hood, and there's also two bolts (may just be one) that have heavy gauge 12v wires attached to them that are on the "firewall" close to the engine in the same compartment that are also exposed so careful of them too.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
