06-05-2013, 11:09 AM | #3763 | |
Yr1OfD1
107
Rep 900
Closing side mirror with Fob set as aktiv Fembody 3110 ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN Opening side mirror with Fob set as aktiv Fembody 3110 ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN
2015 328i Gran Turismo M Sport
2013 328i XDrive Sedan M Sport 2011 X5 xDrive50i 2009 X5 xDrive 30i 2008 135i Coupe |
06-05-2013, 11:18 AM | #3764 | ||
Rep 40,789
For this you need NBT Head Unit, which unfortunately your 2013 U.S. F30 does not have unless you retrofitted it, and the FDL Code is: HU_NBT = > STARTUP_EMBLEM = variant_xx
06-05-2013, 11:41 AM | #3765 |
Rep 1,892
Plus you have to change FEM_BODY / 3053 / KOMFORTSCHLIESSEN_FB to aktiv in order for the mirrors to fold/unfold via the fob. CA fold/unfold is enabled by default.
06-05-2013, 12:34 PM | #3766 | |
Rep 1,130
Drives: '16 340i AW MSport
There you are! I'll check it out, but wait I'm confused on why that represents a conflict, in my car even if i'm on switch position four the DRL's (which are the corona rings) remain on the whole time the car is on? on your F10 Position 4 = no lights on at all? I'll investigate the WL_FUNKTION_POL lead.... |
06-05-2013, 04:24 PM | #3767 | |
Rep 1,130
Translation of comments: Comment = Welcome Light: 0 - disabled 1 - activation with light switch in position A (Auto) 2 - activation with light switch in position A (Auto) OR 2 Its already set to 2, not sure what Position 2 is, but its not the one I want lol, maybe I can't change it. |
06-05-2013, 06:33 PM | #3768 | |
Rep 40,789
06-05-2013, 08:20 PM | #3769 | |
Rep 490
Without coding, some people feel the pain of headlights staying on despite what seems to be bright environment, and the welcome lights only stay on for a brief period, so traditional thinking on and off, can't be a good thing, so there better be a switch that I can turn that off |
06-05-2013, 08:37 PM | #3770 | |
Rep 1,130
06-05-2013, 09:07 PM | #3771 | |
Rep 40,789
06-05-2013, 09:40 PM | #3772 | |
Rep 490
and trust me, a lot of owners never explore their menu, and don't really know what seems to be very basic stuff |
06-05-2013, 09:49 PM | #3773 |
Rep 3
Hello,
My f30 has i-step 12-11-504. I have coded it with 3.18.4 and psdzdata 48.1. After FA coding I decided to update ECU after i did that procedure Connect => Read FA => Activate FA => Read VCM => Left-Click on KOMBI => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on INHK (the ECU itself not the underlying CAFD) => Select CODE I think I have coded ECU with 12-11-502. If I use 3.128.4 and psdzdata 48.3 can I upgrade Kombi ECU back to 12-11-504? Thank for advance. |
06-05-2013, 10:10 PM | #3774 | |
Rep 40,789
If it is working now, leave it alone. Changing the CAFD won't make any difference.
06-06-2013, 12:43 AM | #3775 |
Rep 3
This story started earlier. I decided to unlock video in motion, make memory for start stop function and to enable current speed at dashboard display. All of that I have done through fdl. Everything was fine but, before coding my trunk was opening together with the doors and it was very convinient for me but after I have coded all options I want trunk started to open without doors opening. To fix that and to make start stop coded through FA I have added to HO-Wort OMSA for start stop and OENE for trunk opening with doors. After that I decided to make operation I have described in my previous post for FEM and Kombi. I wasn't able to read fem because e-sys showed me message with error, during kombi reading there was no any problems with reading and I coded it with 12-11-502. After that kombi and it cafds became not blue as other ECUs but black. And at the top of ecus tree in brackets it written 18 colored black and after coma 1colored red. I think first figure is numher of all ecus and second is kombi ecu with another version. Sorry for such long text.
06-06-2013, 09:07 PM | #3777 |
Rep 40,789
PM sent.
06-06-2013, 09:55 PM | #3778 |
MSGT USMC (Ret)
18
Rep 276
Drives: 2012 AW F10 535i M-Sport
Operating systems that can be used
I bought a laptop for coding that has Win8. Can we code with Win8 or do I need to have a separate HD with Win XP or 7?
Mark |
06-06-2013, 09:59 PM | #3779 |
Rep 40,789
Win 8 is fine, including 64 Bit.
06-07-2013, 01:33 PM | #3780 |
Rep 226
Sorry for the derail but could anyone direct me to a similar thread for coding for the E84? Good friend just picked one up and wants to know if he can get Bluetooth A2DP (only has bluetooth phone). Checked the E84 forum but did not find one. Thanks!!
06-08-2013, 04:49 PM | #3781 |
Rep 4
Hi shawnsheridan, would you please email me the link? I'm at F020-12-11-502. Thank you! rizight1@gmail.com
06-08-2013, 05:32 PM | #3782 | |
Rep 40,789
Case in point. F020-12-11-502 is both ISTA/P 2.48.0 and ISTA/P 2.48.1. If you got 48.0, and the car has 48.1, then you may very well not have what you need. Ideally, you always want the latest PSdZData anyway, but this became complicated by the transition to E-Sys 3.22.5 and some people's reluctance to update if it was not needed, due to the cost of doing so. In your case, I presume you are using E-Sys 3.18.4, which for F20 / F30 Chassis, the latest you can use without updating is 48.2. E-Mail sent.
06-08-2013, 05:43 PM | #3783 |
Rep 4
Understood. I realized according to the charts it could be 48.0 or 48.1 but I was hoping you'd link me to 48.1 or 48.2 assuming I'd want to milk E-Sys 3.18.4 as long as I can and you did. Thank you again!
06-09-2013, 04:55 AM | #3784 |
///M-Flight
Rep 10
If you are having trouble locating the 511 ohm .6 watt resister I can help. I found them at Mouser Electronics which is an online electronic store used by car companies. The Mouser P/N is 594-mrs25000c5110frp. I have had no problems with them shipping to an APO address either. I hope this helps.
