BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Vibrations at +60 mph
      12-20-2022, 11:12 AM   #1
90rr
90rr's Avatar
Drives: 2021 M340i
I'm noticing vibrations at speeds above 60mph (under 60 is a smooth ride). It's loud and noticeable near the armrest. I had a drive shaft checked and a new center bearing installed, but the vibrations persisted. Do you have any ideas what it could be?
The rear tires, springs, wheel bearings and shocks have all been replaced recently.
Thank you.
      12-21-2022, 09:31 AM   #2
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
Could be bent rim, could be alignment…. could be warped tire. Did it start happening after the temp outside dropped?
Stage 2 BM3
Originally Posted by GrussGott View Post
Sounds pizzagatey.
      12-21-2022, 10:54 AM   #3
Tommy D
Drives: '17 BMW 440i GC, 2005 BMW 330i
Vibrations in the steering wheel or in the center console area? Maybe the Splash shields are loose and flapping around?
      12-21-2022, 11:37 AM   #4
HighlandPete
Drives: BMW F11 535i Touring
Thank you.
You have a lot of changes in your post... when and/or how did it start vibrating? Better or worse, with the changes you have made?
335i, vibrations
