11-29-2009, 11:03 PM | #23 | |
Rep 1,690
Drives: 911 992 C2S
If I recall reading an article about the gearbox, the spokes person from ZF said that when creating this unit, their goals were: 1) More fuel efficiency 2) More power efficiency and the number of gears were not an important data point other than whats needed for the above 2 points. I agree 8 sounds too much and is annoying when doing manual shifting using paddles, but when i was driving my 335i AT, the 1st gear was almost never used unless I was at a red light trying to beat someone. otherwise, i would use the paddles to shift up or down never caring which actual gear i was at so 6 or 8 probably won't make much difference. face it, auto gear boxes are the not going to be what you think in a few years and we may end up with 10 gears or something like CVT to completey do away with gears. I recall reading somewhere this box has 5 clutches which if true means that DCT boxes will seem like a interesting experiment of the past in a few years while everyone jumps on similar tech. |
11-29-2009, 11:08 PM | #24 |
Rep 1,690
Drives: 911 992 C2S
11-30-2009, 02:35 AM | #25 |
Rep 44
From a European perspective, the 8 speed auto seems great. We drive through Germany a lot, and even though my 335d doesn't rev a lot, two extra gears would be great when you travel at speeds above 150-160 km/h. Great improvement in my opinion.
/Christian |
11-30-2009, 03:39 AM | #26 |
Rep 42
So far, magazine road tests of the 5 Series GT and 760 Li have been very complimentary about the new 8 - speed 'box. Always in the right gear, almost imperceptible shifts.
Yes, the Merc 7 - speed and Lexus 8 - speed have come in for criticism, especially for being unsure what gear they want to be in. The new ZF is nothing like them ! ! The ZF 6 - speed was widely regarded as the best automatic you could get. The new 8 - speed moves the game on. It's not just the 6 - speed with an extra gear top and bottom, but quite different internally, improving its efficiency. The fact that the new 520d will have this 'box makes an even bigger mockery of MB's decision to give the 4 cylinder E-Class the 5 -speeder. Stewart. |
11-30-2009, 04:46 AM | #27 |
Rep 1,898
I think 8 speed are great! I've the 7 gear DCT and I really value the additional gear. low revs when cruising, amazing fuel economy. especially with low rev high torque engines like the 335i, it works flawless. it can easy pull in 7th with 1400 rpm. when pushing the shorter gears are good, and with the seamless shifting no time is lost when shifting. I agree that with a manual box it would make less sense. Let's see.
11-30-2009, 09:45 PM | #31 |
Rep 80
There is also a nice vid about the 8spd on the ZF website.
Check it out at http://www.zf.com/corporate/en/produ...nsmission.html ... |
11-30-2009, 10:56 PM | #33 |
Tire Racks
53
Rep 1,232
12-01-2009, 02:15 AM | #35 |
Rep 8,016
It says in the info that it takes 200ms to execute a shift but I was sure we were told it was quicker than that. My memory must be acting up in my old age.
In any case it didn't feel much different to that of the DCT though clearly it was. |
12-01-2009, 12:06 PM | #36 |
Rep 2,475
Start stop feature coming to automatics
Wouldn't this get pretty annoying if you have an aftermarket exhaust? My car constantly shutting off and then back on during rush hour might get irritating...
I understand this will be implemented to reduce emissions, and is a part of BMW big efficient dynamics plan. http://www.bimmerfile.com/2009/11/30...to-automatics/ We have heard from reliable sources that BMW along with ZF have been developing the newest 8 speed transmission to also work with Stop/Start. Stop/Start is a technology developed to allow the engine to turn off automatically when the car is stopped for a period of time (at a traffic light) and the engine will turn back on when the accelerator is depressed. Currently, this technology has been reserved for 4 cylinder engines coupled with a manual transmission in markets outside the US. This new offering would allow the use of Stop/Start in vehicles with larger displacements and of course in different markets that prefer the automatic. Earlier in the year we learned that BMW will be transitioning its current lineup of 6 speed autos to 8 speeds by model year 2013. The 8 speed debuted in the 760Li and will be featured in the 5 GT as well as the 5 series this spring. There has been no set date as to when this new feature will make it’s debut but one can expect it first in the 7 Series hybrid this spring and other models after.
2020 /// M2 Competition
Past: 2016 435i ZHP Edition | 2013 335i | 2011 135i | 2008 328i | 2006 325i |
12-02-2009, 04:13 PM | #37 | |
Special Agent
74
Rep 1,731
Not sure if I had mentioned it before but after driving the 8 speed in a variety of situations I can say that it is fine transmission and can't wait to try it in the TU form (faster shifts like the 335 version thanks to the upgraded torque converter etc.).
[SIGPIC][/SIGPIC]
12-03-2009, 02:27 PM | #39 |
Special Agent
74
Rep 1,731
8 speed will be the end all (not 10 speed etc.), BMW and ZF had created all sorts of algorithms and computer simulations that basically state that anything greater than 8 is pointless (unless there are infinite ratios...)
The ability it has to skip gears and not hunt and peck for the optimal gear on the upshift is leaps and bounds above other brands itinerations.
[SIGPIC][/SIGPIC]
