BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Software Update/Version Blank!
      08-09-2016, 04:13 AM   #1
Crombie
Drives: 2012 F30 318D Luxury
Hi All,
Hopefully someone can help as Im tearing my hair out!
When I try and view the current software version, I basically get a blank... Photo attached
To download and install update, I do the following:
Access www.bmw.com/update
Entered my VIN
Downloaded the *.bin update
Formated 3 separate USB keys in FAT32(also tried NTFS)
Copied *.bin to each
Tried each USB in the USB slot in my centre console glovebox
Accessed the 'Software Update' option on 'Settings' menu in the Control Display.
The following message appeared on all occasions:
"Update on USB device not suitable for this vechile...."
I can assure you the VIN is correct.
      08-09-2016, 06:04 AM   #2
teaston
Drives: X3 M40d
Looks like you can't do it because your car has the base non nav head unit
      08-09-2016, 07:12 AM   #3
Crombie
I checked the build spec and confirmed I should have this -
6NH Hands-free Facility W. Usb Interfac.
      08-09-2016, 07:26 AM   #4
teaston
Drives: X3 M40d
USB interface could just mean for playing music from a phone or stick.
      08-09-2016, 07:38 AM   #5
Crombie
I believe.....
6NH Hands-free facility with USB interface wireless connection for compatible Bluetooth mobile phones (see http://www.bmw.com/bluetooth) with the vehicle, including hands-free facility. Enables convenient connection of an MP3 player, Apple iPod or USB memory stick in the vehicle. Playback of the audio files via the vehicle's audio system, operation by equipment-dependent controls (radio controls, multifunction for steering wheel) of the vehicle. Including 12 V power socket in storage compartment of armrest front
      08-09-2016, 07:43 AM   #6
teaston
Drives: X3 M40d
I believe.....
Exactly
      08-09-2016, 07:56 AM   #7
Crombie
Exactly
Right, well to get back to the original issue, how can I check what version of software is already installed and secondly, how can I install new software successfully?
Is there anyway to reset the iDrive software(factory reset)?
      08-09-2016, 08:06 AM   #8
teaston
Drives: X3 M40d
I've just had a thought, do you have a USB socket in the glovebox?
      08-09-2016, 08:18 AM   #9
Crombie
No need to take the piss. Im looking for assistance, not a hard time. Youve had a read of post 1.
I might be a newbie but we all started somewhere. Anyone who can help, it would be greatly appreciated.
      08-09-2016, 08:22 AM   #10
teaston
Drives: X3 M40d
WTF?! I'm being serious!
Just look in your glovebox on the left.
      08-09-2016, 09:02 AM   #11
Crombie
Sorry, tearing hair out here...
This is exactly what Ive done on numerous USB keys, about 6 brands at this stage.
Copied *.bin from www.bmw.com/update to USB
"Update on USB device not suitable for this vehicle...."
      08-09-2016, 09:14 AM   #12
philiper1
philiper1's Avatar
England
771
Drives: F21 M135i LCI
what are you trying to update anyway? sorry if I have missed it somewhere
Current: F21 M135i Mineral Grey and few options
Previous: F30 320i XDrive, E85 2.5i, E21 323i
      08-09-2016, 09:15 AM   #13
moonshine
moonshine's Avatar
Scotland
849
Drives: 718 Boxster S
are you using a mac or a pc?
formatting a USB on a mac leaves relic hidden files that prevent the USB from being recognised....
if you are using a mac, try formatting in a pc. I'll see if I can remember how to remove the hidden files from a mac.
you need to run an app that deletes the Mac files on eject
      08-09-2016, 09:20 AM   #14
Crombie
I want to update the software on the iDrive as Bluetooth does not work. Teh car will not connect with any phone, tried 6 including an old Nokia I have lying around. Bluetooth was enabled on all phones.
Also, when USB is plugged into centre glovebox does not pick up mp3.
I was thinking a software update might help. Then when I try and view what software version I currently have installed, I get a blank, literally!
      08-09-2016, 09:21 AM   #15
Crombie
Using a PC. Formatted half a dozen USB's in FAT32, even tried NTFS is vain!
      08-09-2016, 09:30 AM   #16
moonshine
moonshine's Avatar
Scotland
849
@teaston wasn't "taking the piss"
it was a serious question.. I'll hopefully explain
normally the "glove box" means the lockable storage bin in the passenger footwell, vs the armrest, which sits between the seats.
you have kind of given a mixed message by saying central glove box (by which I think you mean the armrest)
my old e89 z4 had a USB socket in the glove box (not the armrest) which was used for navigation updates, and I think this is what teaston was exploring.
as I (and I suspect teaston) don't have your version of idrive, I don't know if you have a different USB layout. and it may be that you have a USB port in the glove box ( but maybe not)
      08-09-2016, 09:37 AM   #17
Crombie
Ok, Thanks,
Just to be clear, all my attempts have been using the armrest USB. I have a feeling this is the correct USB as when I insert the usb with update software, I get an error as follows-
      08-09-2016, 09:41 AM   #18
moonshine
moonshine's Avatar
Scotland
849
ok, it looked like we can't help you.
can you pop into a dealer and get one of the genius chaps to look into your issue?
might be the best thing to do
      08-09-2016, 09:42 AM   #19
teaston
Drives: X3 M40d
It sounds like you have a hardware fault then if nothing will work on Bluetooth or USB
      08-09-2016, 09:45 AM   #20
Rukka
Rukka's Avatar
2647
Drives: M4 Comp
Crombie;
a couple of things to try/test.
Can you save your profile to USB? In the idrive settings go to PROFILES - EXPORT and see if you can save it to the USB drive you have plugged it.
If yes - it proves that your USB stick is readable and the USB port works.
If no - either A, look for second USB port in the Glovebox as teaston says or B (if you only have the one in the Center Armrest) - your USB is fcuked.
Now, the update itself - did you get it from www.bmw.com/update ? If so, that is the American site - try getting the update form the UK site
http://www.bmw.co.uk/en_GB/topics/ow...es/update.html
Rukka
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87
      08-09-2016, 10:08 AM   #21
Crombie
Originally Posted by Rukka View Post
Crombie;
Rukka
I will try to export a profile after work. I tried www.bmw.com/update and http://www.bmw.co.uk/en_GB/topics/ow...es/update.html. I think both are the same but tried them separately all the same. No joy there!
      08-09-2016, 12:33 PM   #22
KM79
KM79's Avatar
Scotland
140
Drives: 2017 335D Msport Saloon
Pull the battery for 30 mins and try again.
bluetooth, idrive, software
