12-12-2019, 04:40 PM | #15071 | |
Rep 40,980
You can run Exx and Fxx software on same PC. There is no common folders or conflicts.
12-18-2019, 02:47 AM | #15072 |
Rep 5
Hello Shawn,
Have a F30 (2013 335xi) and finally going to start coding. Can you send me the links/files so I can get some things adjusted on this car. Thanks so much! |
12-18-2019, 03:13 PM | #15073 |
Rep 40,980
PM sent.
12-18-2019, 04:37 PM | #15075 |
Rep 2
12-18-2019, 04:38 PM | #15076 | |
Rep 40,980
12-19-2019, 02:02 PM | #15077 |
Rep 51
Hi
I've just swapped my 2015 F30 for a 2019 F36 and want to fit the aftermarket reversing camera taken form the F30. The supplier says it will fit OK with NBT EVO and as per the F30 needs 3AG adding to the VO. As this is aftermarket I'd prefer not to VO code. Is it possible to add 3AG to FA and code and then remove 3AG from FA and write but not code ECU's TIA |
12-19-2019, 02:06 PM | #15078 | |
Rep 40,980
12-19-2019, 03:20 PM | #15080 |
Rep 40,980
Yes, Edit FA, Save FA, load FA in Coding Module, and then Activate FA and VO Code ECU(s).
12-19-2019, 03:27 PM | #15081 |
Rep 51
12-19-2019, 03:30 PM | #15082 |
Rep 40,980
12-20-2019, 04:11 AM | #15083 |
Rep 2
12-20-2019, 05:36 AM | #15084 |
Rep 40,980
I do not use BimmerCode, so I do not know anything about it. If the Backup was made with original factory coding, I would expect so.
12-21-2019, 08:51 AM | #15085 | |
Rep 51
Reading FA from the vehicle now shows 3AG as an option. Did I miss something or have a wrong setting or option. |
12-21-2019, 09:01 AM | #15086 |
Rep 40,980
If you do not want FA written to car, "Update VCM" cannot be checked under E-Sys Options.
12-21-2019, 02:10 PM | #15089 |
Rep 40,980
PM sent.
12-22-2019, 11:56 AM | #15090 |
Rep 19
Hi Shawn, I am moving from my E90 to an F30, can you please send me a link to the files? I think you might've originally hooked me up with the E90 stuff back in the day that ended up working for me.
Thanks. |
12-22-2019, 11:57 AM | #15091 |
Rep 40,980
PM sent.
