BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > DEPO F30/31 Projector Headlights **UK Photos and Chat thread**
      10-06-2017, 03:40 PM   #1453
UKF30
UKF30's Avatar
Drives: BMW G30 LCI Black Saphire
Originally Posted by Dzurifuri View Post
Yeah i had H7 all this time. During day time no probs but night time is bad especially if there is no other lights around.
I ordered now 35w 5000K hid kit. I understand that is the option that most of you went for.
Is it difficult to install them on Depos?
I have no idea how difficult to fit after headlights fitted mate as we did it when headlights were out but I do know High beam bulbs are nightmare to change mate .
perhaps someone else can help who fitted HId afterwards.
      10-06-2017, 03:48 PM   #1454
Dzurifuri
Dzurifuri's Avatar
Drives: 2007 BMW 325d Msport (E90)
Well, i guess we will have to take bumper off again ?
Toms Lagzdins
      10-06-2017, 04:28 PM   #1455
UKF30
UKF30's Avatar
I would say try it first see how hard it is before taking bumper off mate , you should be able to do it it's just fiddly that all
Give it a try first and then have bumper off last option .
      10-06-2017, 04:30 PM   #1456
Dzurifuri
Dzurifuri's Avatar
Will do mate. I am hoping that just turning wheels one side should give me enough access
Toms Lagzdins
      10-06-2017, 04:32 PM   #1457
UKF30
UKF30's Avatar
Good luck let us know if you need any help mate
      10-06-2017, 04:34 PM   #1458
Dzurifuri
Dzurifuri's Avatar
Will do, cheers.
As soon as this will be completed i will post a pic
Toms Lagzdins
      10-12-2017, 06:04 AM   #1459
Dzurifuri
Dzurifuri's Avatar
Will do, cheers.
Super excited, got my HID KIT today and will be settig it up later tonight
Toms Lagzdins
      10-16-2017, 06:48 AM   #1460
tristancliffe
tristancliffe's Avatar
Drives: 2012 F31 320d Sport
Are the motor levelling warnings common? Is it something we just have to live with (they spend 99% of their time on 0 anyway, but with heavy loads it is useful to be able to lower them), or is it a result of something breaking?
Very tempted to get these, but I don't think I could put up with errors, even if the solution is to just not use the dash knob.
      10-16-2017, 05:04 PM   #1461
6times7
Drives: F31 330d
Yeah, i think the warning is fairly common having followed this thread from early days. I think it's a result of a soft/hardware glitch in the units.
Having had a pair of the Depos fitted, my low beams go through the levelling up and down if they come on when the car is started no problem. However, if i start moving the adjustment wheel i soon get an error. I reckon there's enough time to crank them down if necessary though.
It's a small price to pay for losing halogens.
      10-17-2017, 07:04 AM   #1462
tristancliffe
Thanks. Much appreciated. I can probably live with that, but I don't want regular errors because it'll make selling the car on harder.
Looks like I'll have to get a pair, fit them, and then save up for the HID bulbs at a later date. Are the projectors with halogens better than the standard reflectors (not that I mind - I find halogens absolutely fine and rarely even bother with high beam, but I do want the angel eyes/halos)?
      10-17-2017, 10:34 AM   #1463
Sturrock
Drives: F31
Was thinking of getting this done but now you say that it throws up errors not so keen. Is this a standard known issue or just occasional??
      10-17-2017, 01:44 PM   #1464
6times7
Drives: F31 330d
Sorry, no idea on halogens/projectors. If you want to stagger fitting I'd say go Phillips diamond vision halogens in the meantime. If you're happy with halogens, for £20ish they are a significant improvement. Make sure you get appropriate high beams fitted before you fit depos as it's bumper off to change.
      10-17-2017, 01:46 PM   #1465
6times7
Drives: F31 330d
They only throw errors when you start adjusting them, and even then not straight away. Errors clear on next start up.
I seem to recall you can fit the self levelling light switch unit, which doesn't have the level adjust wheel, if you don't want codes thrown. See this linky. They are on E-bay for 49 Euros - search for bmw f30 control element light.
      10-18-2017, 07:24 AM   #1466
Sturrock
Drives: F31
Cheers bud. Kinda gone off the idea now. Thought it was a straight forward plug and play, but seems there's a little more to it.
      10-18-2017, 06:19 PM   #1467
Dzurifuri
Dzurifuri's Avatar
Will do, cheers.
Hid fitted and look 100 times better
Toms Lagzdins
      10-21-2017, 03:43 PM   #1468
Darudis
Drives: F31 330D
Hi guys I've got depo lights as well and I love them but I get the same error like most of you guys About the levelling motors, but I get this as soon as I get in the car in my case it fails on first check (when you start the car or turn on the lights they go up and down) so I always have the yellow triangle on dash. This can be sorted bet changing resistance parameters in frm, but I don't know which ones yet, maybe some of already known this?
So I don't even need to use the levelling switch (wheel with numbers 0 1 2 3) to get this error like most of you "lucky you"
BTW this beam levelling switch is made for: if you put heavy luggage in boot rear end will go down and the headlight beam will go up and you will be dizzying on coming Trafic so then you have to use that wheel and choose setting 1 2 or 3 depending how much you loaded your car this will set the beam lower (0 is default setting and 3 is the lowest one)
Your help and thoughts would be much appreciated we can sort it together
      10-22-2017, 04:03 PM   #1469
tristancliffe
With that and not being able to change high beam bulbs in situ is a serious turn off.
      10-29-2017, 03:44 AM   #1470
Darudis
Drives: F31 330D
Guys did any of you managed to sort out the levelling issue? Or found a solution for it, I have this error all the time
      10-29-2017, 01:40 PM   #1471
6times7
Drives: F31 330d
I only get the error when adjusting, not all the time.
You could try disconnecting bulbs, adjust the wheel to the mid point, or other end of its range, let the car go to sleep (ignition off for 15 mins, 30 to be safe) reconnect the headlamps then try igntition on.
Other than that have a chat with Eurowagens, assuming that's were you got them.
      11-29-2017, 04:07 AM   #1472
tristancliffe
Ordered a pair of these, which have arrived, and waiting for bulbs and HID kit...
What coding is required?
I'm guessing I'll need to turn off Voltage Monitoring for the daytime running lights and sidelights? What about the low beam (HID)?
Hoping to get it fitted this weekend, but if bulbs don't arrive in time I'll rearrange for next week.
      11-29-2017, 07:39 AM   #1473
BrennanF30
BMWLad
BrennanF30's Avatar
Ireland
1469
Drives: 320D M Sport
BMW F30 M Sport  [0.00]
No coding required, fully plug and play
AW F30 with M Performance Kit, Quantum44 SFF1 wheels
I don't know - BrennanF30 is Irish isn't he? I reckon he's got some super hi def, Ultra HD4K F30 photo taking potato
      12-15-2017, 03:15 AM   #1474
TopperXP
TopperXP's Avatar
Drives: BMW F30 320i m sport / BMW F40
Going to bite the bullet and get a pair , which kit from HID4u is the correct one ?
