BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Anyone know where the comfort access system is located?
      02-16-2018, 11:29 PM   #1
BMW DIY Guy
Drives: 2014 435i
Hey yall:
Shocker.. the dealership didn't give me accurate information. Call me surprised.
So my comfort access system is a little flakey at times and seems sensor related. Randomly it works perfectly, door opens, locks, unlocks, car starts etc with no issues. Random time later, it will complain it cant see my key, touching the door handle to lock or unlock doesn't work etc.
Seems like a bad sensor, so I bought the part and went to replace it today.
https://www.ecstuning.com/b-genuine-...n/65209220832/
I was TOLD it is in the drivers door, but couldn't find it after going through the whole door, pulling the vapor barrier, etc.
My next guess is that it is in the steering column since you are supposed to hold your key up to that marked spot if its not being seen well? The sensor is about the size of a pack of Wrigleys gum, but no clue now of where it might be.
Anyone replaced yours before and or know where it is?
Thanks!
Check out my DIY Channel on YouTube!
F32, F80, E39, E46, E53, and E83 projects from Pro Auto Motion, Active Autowerke, AvinUSA, Karbonius Composites, Ignition Projects, Go Fast Bits and more!
** BMW DIY Guy **
      02-17-2018, 02:19 AM   #2
IK6SPEED
IK6SPEED's Avatar
Drives: BMW M235i / AH3
Diagram is misleading for the unit your purchased.
In F32, front center console (close to gear shift), rear center console (near vents) and in rear of car.
Exterior is under door behind side skirt and in rear.
I doubt what you have purchased is your issue.
Stable: F22 M235I / AH3
Past: F80 ZCP /E89 35is
      02-17-2018, 11:13 AM   #3
Billfitz
Drives: '15 328iX GT
It makes sense that there are two different antenna systems. Inside the car there would have to be a number of antennae with very low sensitivity, as that's the only arrangement that would allow the system to detect that the fob is inside the car to allow starting it, and not outside close by the car. The second system would be long range, to communicate with the fob outside the car at a distance. Logic dictates that if neither system is working that the fault probably lies with the fob. Does this happen with both your fobs, or only one?
      02-17-2018, 11:23 AM   #4
BMW DIY Guy
Drives: 2014 435i
Happens with both, though granted I haven't tested the second one in more than 6th months. Swapping fobs was one of the first things I did, then new batteries, then like 3 trips to the dealership for it prior to warranty expiring.
** BMW DIY Guy **
      02-17-2018, 11:28 AM   #5
BMW DIY Guy
Drives: 2014 435i
Yeah.. I am more than a little pissed at the dealership now, when I actually thought they were great. They said and quoting as close as I can "the sensor in the door is the problem, and looks damaged but due to what appears to be "custom speakers" we cant cover that under warranty". Well that makes sense.. *IF* the sensor was IN the door, AND if there were "custom speakers". Now that I have taken the door card off, its clear there was no damage, change, and still stock speakers... and no @#$@#$@ sensor in the "door".
Its probably good I wont be back there again any time soon.
I appreciate the additional info and it looks like I have the interior antenna for sure, and if I found the front one could swap it out but now who knows if it is actually the issue.
** BMW DIY Guy **
      02-17-2018, 02:56 PM   #6
Billfitz
This shows where the side antenna is:
https://www.newtis.info/tisv2/a/en/f...ilter/JywIW4Qo
It's not even in the door, so your dealer is AFU.
