06-16-2018, 11:42 PM | #1 |
e90noob
1588
Rep 1,862
(LA) F30 M14x1.25 wheel studs and nuts and locks
I got rid of my F30 and these don't fit my new car I have the following for sale M14x1.25 wheel studs and nuts (F30 fitment) wheel studs are 60mm in length (i used 5mm and 12mm wheel spacers with these studs) 30 wheel studs 20 nuts 5 locking nuts + key + 2 open nuts to use for install/uninstall $75 for everything (also have 18x8.5 Apex Arc-8 wheels for sale) Can sell all together or separately all parts are from Motorsporthardware.com (10) unused wheel studs (20) used wheel studs total of 30 studs + 2 M14x1.25 open lug nuts so you can use the "double nut" method to install and uninstall the wheel studs (some of the hex/allen key holes are not perfect. it's more secure to use the double nut) (20) used MH Titan cold forged nuts, gunmetal color (4 are basically new since i used the locking nut instead) (5) used MH titan cold forged locking nuts, gunmetal in color + key (1 nut is new since i used 4) i used the wheel studs and nuts/locking nuts for 1 year used for 1 track day, 1 autocross day, and just daily driving some people may say don't ever buy used wheel studs because they are consumables and they can break i think that's if you're hardcore tracking and putting massive stress on the studs ... or not using the correct torque value the price is taking all of that into consideration take this opportunity to try out wheel studs for cheap without over-committing to it this is what it looked like installed together the used wheel studs and nuts are dirty and have surface rust from normal usage does not interfere with use give it a good brushing and clean them up if you just want the MH nuts and locking nuts, $60 located in Los Angeles
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22 Last edited by XKxRome0ox; 07-03-2018 at 11:41 AM.. |
06-21-2018, 01:36 PM | #2 |
e90noob
1588
Rep 1,862
no one wants these nuts?
Production date - 2008-04-22 Last edited by XKxRome0ox; 06-27-2018 at 06:08 PM.. |
07-16-2018, 02:48 AM | #4 |
Rep 4,456
So this is a stud conversion set up? Just wanting to make sure I am reading everything correct? Could these studs be used with out spacers and the nuts on OEM wheels?
Thanks |
07-16-2018, 08:50 AM | #5 | |
e90noob
1588
Rep 1,862
you can use spacers or not you use the race nuts included in this instead of the original wheel bolts yes, you can use with OEM wheels
Production date - 2008-04-22 |
07-16-2018, 09:07 PM | #6 |
Rep 1,044
XKxRome0ox1587.50 FaRKle!4016.00 |
