BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F30 Aragosta Type S (Topline Japan) Coilovers
Studio RSR
      10-28-2014, 12:37 AM   #1
robnval
Drives: Java Green F80
Just wanted to share a couple quick iPhone pics since these came in today. They are not reflected yet in the Aragosta catalog but will be very soon!
Installed pics coming soon
      10-28-2014, 07:36 AM   #2
Someguywitha-f30
Respect Big Pimpin'
Someguywitha-f30's Avatar
Taiwan
Drives: 08 AW E92 M3/13 EBII F30 328i
How much did it cost? Waiting for installed pics!
      10-28-2014, 12:37 PM   #3
robnval
Cost is in line with AST/Moton etc, since these use the same cores. (Slightly more than KW V3) I will likely install Friday evening (hawaii time) and align Saturday morning so pics will be up this weekend
      10-31-2014, 11:18 PM   #4
robnval
Quick iPhone update..
      11-02-2014, 01:50 PM   #5
robnval
Alignment done and put around 150 miles on the car yesterday... Still some minor tweaking to do
      01-25-2015, 02:16 PM   #6
ossanboy
Drives: F30 335i
how much are they? and how is it compare to KW or BS?
      01-27-2015, 04:05 PM   #7
robnval
I believe retail is going to be set around $4k US... IMO, compareable coilovers would be JRZ lines, AST/Moton (same cores so essentially identical minus valving and spring rate and brand). I have ran a few different brands on different cars over the years and I will say that it seems that the higher end stuff has a wider range of damping vs more "off the shelf" setups (kw v2/3, H&R, PSS10 etc). But at the end of the day it really just depends how you plan to use the car.. most people wont want to spend 4k+ on a street use vehicles suspension.
Here's my thoughts on this setup (3500 miles driven so far):
- dampers can be set softer than OEM Msport all the way to extremely solid
- simple damper adjustment front and rear without the use of a jack is great
- even in the sea water environment of hawaii absolutely no issues with rust or "frozen" adjusters
- height adjustment is much greater than they claimed.. can go from full tuck front and rear to maybe 1/8 inch lower than stock
negative:
- experienced slight noise on DS front following alignment. Turns out that the pillowball wasnt perfectly centered in the camber plate when they set it causing slight metallic noise.. recentered and realigned.. noise gone!
Wasn't a huge deal but more of an attention to detail thing that I felt needed to be mentioned.
      10-09-2019, 07:49 PM   #8
ericono
Drives: 1985 M635
Ancient thread revival, but hoping you still have the car and suspension and was looking for a long term update on if you were still satisfied or not?
Thanks,
Eric
      10-10-2019, 05:30 AM   #9
1QuikWS6
No 55mph
1QuikWS6's Avatar
1621
Drives: F32 435ix MSport
Jeez, try focusing the camera
