04-26-2016, 03:28 PM | #89 | |
Rep 1,124
As far as the MPG, I've only really driven it a day or two since I had it installed, and haven't really noticed any changes in the mileage yet. I'll clear my mpg and keep track of it. |
04-26-2016, 06:20 PM | #90 | |
Rep 190,173
05-20-2016, 12:35 PM | #91 |
Rep 38
do you have to unplug the battery to install? Also is it the battery in the trunk or the one in the engine bay? Anything else I should know before installing, like leave the trunk open?
05-23-2016, 01:11 PM | #92 |
Rep 101
Hi Everyone, I am wondering what is the vacuum line used for? How come my Euro model 2014 328 doesn't have it...??
And how to get this awesome woosh sound? Mine doesn't sound like this... rather quite. |
06-27-2016, 12:32 PM | #93 |
Rep 87
So I installed this yesterday and it doesn't seem it has any power gains. It feels the same... I'm not surprised since it's only an intake. Looks and sounds good tho.
02-25-2017, 02:32 PM | #94 |
Rep 13
Just installed mine today and also did not install the long rubber barrier between the heat shield and the lower piping. It was big and long and awkward and even with cutting didn't fit well. I may find something else to wrap around that section of the tube.
Did anyone leave the top of the heat shield off? It's heavy and seems unnecessary. |
06-15-2017, 12:48 PM | #95 |
F30 328i Msports N20+ERDP+CP+TIC+FMIC+MPE+ JB4
Rep 80
i just diy'ed install my intake today and cant believe that the pipes are so filmsy and loose, or i screwed up my install. There is essentially only one vibramount to hold 2 pieces of pipes together after being merged together by provided straight hose. and nothing to hold the lower intake pipe in place. Not sure if it would loose over time and have vibrations and loose item knocking sound. when i push then to simulate movement, i can hear knocking sounds of the pipes.
anyone else has this issue or its just me and my observation. |
09-18-2017, 01:08 PM | #96 |
Rep 276
For the 3rd time, cause nobody feels the need to answer this question!
How often do you clean the filter, and HOW do you clean the filter? Dry filter. How much dirt comes in through the slits in the cover? |
10-04-2017, 07:55 AM | #97 |
Rep 1,207
My opinion, it all depends on how much you use it and where you are (clean or dusty area). I would check it every 3-5k miles but probably won’t need to clean it until 10k or even more. You will know by the amount of dust, dirt and grime that accumulates and your comfort level. I would take out just the filter, use an air compressor or any high pressure air device. If that’s not enough hose it down with water With just enough pressure so it doesn’t damage the filter then let it air dry in the sun. I no longer have the car and device but that is how I use to clean it.
10-05-2017, 05:01 AM | #98 | |
Rep 276
Thx for the answer |
