09-19-2016, 08:59 AM | #23 | |||
Rep 195
I have the AWE Quad touring. I forgot to mention I had to cut about and inch, inch and a half off the plastic under paneling at the battery box as the corner was showing in exhaust opening(passenger side) |
09-19-2016, 09:52 AM | #24 |
Schmollbraten
12512
Rep 1,985
Ah, ok, those are not permitted into Germany, aside from the fact, that for the 4 series are no AWE exhausts available.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
01-01-2017, 10:54 AM | #26 |
Schmollbraten
12512
Rep 1,985
If possible let it be carbon structure wet-print. Matte black would be also ok, EBII is too much for my taste and deletes the visible difference distance between bumper and diffusor.
01-02-2017, 05:32 PM | #27 |
Rep 1,467
Im leaning towards painting the outer gloss
Black to match the trim and leaving the center matte. I agree the eb 2 looks a little odd to me. This would be sportier. |
01-03-2017, 10:19 AM | #28 |
Rep 968
I've got mine with the outer painted BSM and the center left matte. Looks great on my MR f32 imo. Not a fan of painting the outer body colour (though I guess black is a different story)
01-03-2017, 11:36 AM | #29 |
Rep 1,467
01-04-2017, 09:47 PM | #31 |
Rep 299
cf seemed a bargain for only a slight cost premium but cf is hit and miss it seems at that price.
i went for a replica m performance made from Polypropylene as in my mind, it would be more forgiving and durable. most seemed to be made from abs which im told is brittle by comparison. my diffuser was made in taiwan and the fit is perfect.
2018 F30 BMW 340i M Sport
Injen EVO intake, OEM 437m rims, Catted VRSF dp, Magnaflow catback, Activ8 piggyback, Pedalbox. |
01-06-2017, 07:30 PM | #32 | |
Rep 13
Install
01-06-2017, 09:54 PM | #33 | |||
Rep 195
I'm not sure what exhaust set up you went with. I didn't do a write up or guide. The only issue I had with the diffuser on my quad setup was the battery box plastic shroud on the rear passenger side was in the way. I had to use a dremel to shave it down to make it fit. I didn't remove any of the heat shield material. Just plastics on the battery compartment. |
01-07-2017, 03:47 PM | #34 | |
Rep 13
01-07-2017, 03:58 PM | #35 | |||
Rep 195
No, not at all. There's some screws that got to be removed at the underneath bottom section. Then the rest of the clips can be worked with hand pressure. Some of them are secured horizontally. I don't remember which ones they were exactly anymore though. |
01-08-2017, 11:28 AM | #36 | |
Rep 13
http://cnautofans.com/products/carbo...-0449-740.html |
