11-29-2023, 04:47 PM | #1 |
Rep 4
Would it fit?
I got offered a set of Apex ARC-8’s 18x10 in 265/35 squared set up. I have a XDrive 435i , would I be able to run these without any problems ?
11-30-2023, 08:11 AM | #2 |
Rep 4,333
Most likely, it will NOT fit. What is the offset? The rear can possibly fit, however additional negative will be required up front and it will be poking more than moderately.
11-30-2023, 09:01 AM | #4 |
Rep 4,333
Both front and rear will require moderate negative camber to reduce poke and it will still likely cut the tires during compression.
EDIT since the tires are smaller than OEM diameter it may not cut, however if you are not lowered, your x-drive gaps would be even larger. larger gaps and pokey tires will look like a toy car. A cheap deal often leads to more grief than good. Id just get wheels and tires that fit better . Last edited by alohasurftoad; 11-30-2023 at 10:11 AM.. |
pauli18c211.00 |
