BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > How to make N55 355i sound like a 340i with MPPSK?
proTUNING Freaks
      12-24-2018, 03:28 PM   #23
ctbear
Drives: 2015 335i m-sport
Originally Posted by perryo91 View Post
The reason B58 sounds deep is the extra 0.5" downpipe.
If you want to sound close to it go catless, delete resonator, MPE or other well made axleback.
I just got a catless DP for my car and it sounds the tits. VERY minimal drone. 0 drone when I turn my radio up to 25%
My DP is 4" btw so I think that's why its so close.
wow good to know. So the whole exhaust run for the B58 is 0.5" wider than an N55 or just the dp?
Catless dp presents an isue for me being in CA
Do you have a video of your exhaust? would love to hear it. thanks!
      12-25-2018, 04:01 AM   #24
borboa
Mexico
Drives: BMW 435i
1)It does not have a resonator
2) where the valve are opend it acts like a Mufler delete (90%)
Have your resonator delete and have a cutout in your exhaust system or buy an exhaust system that let you have a semi mufler delete like afe exhaust
      12-25-2018, 12:12 PM   #25
doodlebro
Drives: '17 X3 35i
PWG N55s have a smaller downpipe, but EWGs have the same size as the B58.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP
Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280'
ceedawg467.50
      12-25-2018, 04:31 PM   #26
ceedawg
ceedawg's Avatar
468
Drives: 2k15 335i xdrive MSport 6spd
Exactly!
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2
      12-26-2018, 09:15 AM   #27
ctbear
Originally Posted by ceedawg View Post
Exactly!
Ah so my 2015 335i would have an EWG, which is the same size as the B58. So an exhaust setup that can emulate the MPPSK's straight-pipe-when-valved-opened system should can me the desired effect.
      12-26-2018, 12:17 PM   #28
Insane435
Insane435's Avatar
Drives: 435ix M Sport EWG
N55 PWG 3.5"
N55 EWG 4.0"
B58 4.5"
2020 MG M340ix - Dragy: 0-60 3.48
2018 LBB X4M40i - Stock Dragy: 0-60 4.85
Hirads16.00
      12-26-2018, 02:09 PM   #29
ctbear
Originally Posted by Insane435 View Post
N55 PWG 3.5"
N55 EWG 4.0"
B58 4.5"
=\ so still off by 0.5" dang
So is it as easy/straightforward as getting a 4.5" catted downpipe bolted on?
      12-26-2018, 03:51 PM   #30
perryo91
perryo91's Avatar
Uganda
373
Drives: 335
Exactly!
N55 PWG 3.5"
N55 EWG 4.0"
B58 4.5"
This guy is correct. B58 is the biggest which I personally think gives it that nice tone. It's sexy my EWG is close enough so I'm happy
Hi
      12-29-2018, 08:14 PM   #31
ctbear
What exhaust set up do you run?
      12-29-2018, 09:13 PM   #32
the dope steez
Drives: F30 335i M-Sport
I'd be interested to see if anyone on a blind test can tell the difference between EWG and PWG exhaust notes on the same upgraded exhaust system... I highly doubt it.
I have PWG w/catless downpipe and MPE. it's got a great growl to it but what I like the most is that it's not intrusive in the cabin at all. With burbles disabled it would be tough for a passenger to tell I have an aftermarket exhaust - until I roll down the windows.
MPE w/catless downpipe is what I'd do
      12-30-2018, 06:41 PM   #33
perryo91
perryo91's Avatar
Uganda
373
Drives: 335
Catless DP, resonator deleted, MPE
To me it seems like the 4.0" changes it's tone around 4k. It kinda sounds high pitch to me. But yeah it's so hard to compare exhaust differences like that... the chances of two people living close to eachother with the same setup except DP is hard.
Hi
      12-30-2018, 06:48 PM   #34
Logicoeur
Logicoeur's Avatar
993
Drives: F30 335i xDrive
Even though the DP inlets are different sizes,the outlets are the same, the midpipe diameter is the same, and so on. The dp size is irrelevant for these turbos as long as you aren't choking it with a tiny dp.
      12-30-2018, 11:27 PM   #35
ctbear
So you don't attribute the exhaust tone difference to the DP sizing?
      12-31-2018, 06:44 AM   #36
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
Here's mine on a cold start. Can someone post a 340 cold start so we can start comparing?
View post on imgur.com
      12-31-2018, 11:36 AM   #37
XutvJet
Drives: 2011 Cayman Base, 2016 M235
I think it's all in the OEM burble tune with the MPPK equipped 335/435 and the MPE for those cars. The M235 (comes with the MPPK as stock) and with the MPE installed is far more burbly, poppy, and aggressive sounding than a 335/435 with the same exact setup. I can't a difference in sound between a M235 and M240 with the MPE. I have a hard time believing the sound difference is because of the turbo outlet size or the different engine design which the only main difference being a closed deck block vs open.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
      12-31-2018, 01:48 PM   #38
perryo91
perryo91's Avatar
Uganda
373
Drives: 335
The dp size is not irrelevant... 340/335 exhaust piping have the same path. The only difference in the system is the downpipe. Especially if we’re talking about MPPSK which becomes a straight pipe with the valve open.
Sure muffler different. But not different enough to create the huge difference in tone.
You compare a straight pipe 335 and a straight pipe 340 and there will be a difference. Difference being: the DP.
      12-31-2018, 01:53 PM   #39
Logicoeur
Logicoeur's Avatar
993
The dp size is not irrelevant... 340/335 exhaust piping have the same path. The only difference in the system is the downpipe. Especially if we're talking about MPPSK which becomes a straight pipe with the valve open.
Yeah not true. The muffler and exhaust path change the tone far more than the dp size. Moreover, the difference in dp inlet size is a mere .5". The tone people discern is definitely the muffler BECAUSE it essentially acts as a muffler delete. Both these engines sound amazing with a muffler delete.
I posted a photo of the lci MPPSK muffler on the previous page. It's also plausible that some of the exhaust gas still passes through the muffler in sport, and the muffler chamber would still add notes to what we hear.
      12-31-2018, 06:10 PM   #40
perryo91
perryo91's Avatar
Uganda
373
Drives: 335
We can just agree to disagree man, its all good
I believe the tone is due to the downpipe because when I went catless I could hear I was close to the b58 tone. (compared to older 335 catless videos I've heard)
It's like comparing a m235i(EWG) with MPE vs older 335(PWG) with MPE. It doesnt have the tone nor crackles as the m235i. Which can only be attributed to the downpipe.
Hi
      01-01-2019, 12:00 AM   #41
ctbear
You think my 2015 335i with the EWG would be closer to that better tone if setup in a similar manner?
      01-01-2019, 10:17 AM   #42
XutvJet
The crackles are simply a factor of the tuning. The crackles/burbles are tiny amounts of unburned fuel being injected into the motor and burning on exit through the exhaust. The crackles become louder when you open up the exhaust. The MPPK tuning on the later BMW cars is quite a bit more aggressive.
      01-02-2019, 02:35 PM   #43
ctbear
To add to this, I found this post on "pops and crackles" that manufacturers are doing nowadays over at the Focus RS forum:
https://www.focusrs.org/forum/9-focu...ml#post1510881
Very interesting read.
      01-03-2019, 06:12 PM   #44
Hirads
Drives: 2015 335i M-Sport
Originally Posted by redbullfan View Post
I wana know how to get that deep sound that b58 gives as well!
Wagner dp
335, 340, mpe, mppsk, n55
