BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Wheel compatibility between E90 and F30?
      04-07-2018, 10:04 PM   #45
csquared
Drives: 2011 BMW 323i
This is a great thread. Lots of real world info here. Now, does anybody know if 2013 750i OEM wheels will fit on my 2013 335i (F30)
      05-25-2018, 11:14 AM   #46
TuckerPDX
Drives: 2017 440xi GC M Sport
Originally Posted by R12ax7 View Post
A little update from my post back in 2013. I actually ended up swapping the summer/winter tires between the 189s and 193s and turned in my e90 with the 189s switching the 193s to winter use - which ended up being a bad idea, since the tire place ruined a couple of the tires in the process.
Anyway, I ran the 193s with the incorrect aspect ratio for three winters with no real issues. Of course the speedo was about 5 mph off and technically the odometer has some phantom miles on it, but it worked for a couple months of the year. The only issue i ever had was that the traction control calibration was a bit off and i did have some ground clearance issues, but i was on Dinan springs and i think i would have been fine if i didnt drop it.
Now I am in a 2016 340 with the Track Handling Package, which has brought a new problem. It turns out the front Msport calipers just barely scrape the inside of the 193s. I mean we are talking 1, maybe 2 millimeters. I may just file down the edge of the calipers a bit or i have a friend with a lathe who said he could probably make a small channel in the wheel, but just a PSA for those with the Msport brakes. Sorry for the terrible cell phone pics.
I saw the picture of your f30 with 193s for winter on another thread and thought I'd ask your opinion on using them on my f36. I have a 2017 430i GC M Sport (non-M brakes) with M400 wheels (square). I picked up a really nice set of staggered 193s, and am thinking of using those for summer. I currently have Blizzaks on my M400s and I'm way overdue getting them swapped out. What are your thoughts on using the 193s for summer?
      06-08-2018, 11:01 AM   #47
TuckerPDX
Just a quick follow up. I ended up putting Pilot AS3+ on my 193M wheels, and it worked out well. Even with the rear offset, I think they look great.
      09-16-2018, 07:35 AM   #48
Herakles
Drives: United States
those sane wheels on my 2011 msport - so you just put a higher profile tire on it? I was going to get 18” msport f30 wheels since my current 19s always blow tires and crack wheels with pot holes maybe my tires just need to change ?
Would the 18" f30 Msport wheels fit fine? Sounds like i would just need a 10mm rear spacers? The 18s will probably help make the car ride much nicer too.
