BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Europe NEXT 2015-2 Maps are now available
      06-29-2015, 03:05 AM   #89
Rockett100
England
Drives: 320d m-sport F31
Hi,
Hope someone can help! I tried to update my nav maps to Europe MOVE 2015-1 last night but the code I generated was incorrect and this morning it’s still asking for a code so I have no nav at this point. I followed the instruction given at the beginning of this thread. I think I went through the steps correctly but being new to this I could have got it very wrong! Changed the lookup file to show the new maps (think I got this correct!) and the code was generated. Could my issue be that I’m using a 64 bit windows 7 machine? I have a funny feeling I read the FSC generator programme only works on 32 bit windows although it did give a code. Any help would be greatly appreciated!
      06-29-2015, 03:25 AM   #90
nordberg
Drives: F31 330d M Sport
Originally Posted by Rockett100 View Post
Hi,
I had exactly the same issue. Never got to the bottom of it. I work in IT for a living so I'm pretty competent at this sort of thing. There's definitely something about the code generator that doesn't like certain cars...
In the end, I sent my DE to another user who kindly generated me a code.
      06-29-2015, 03:26 AM   #91
nordberg
PS: to get working at the moment, you should have the original activation key on a bit of card in with your owner's manual etc....
      06-29-2015, 03:41 AM   #92
Rockett100
England
Thanks for the quick reply! I didn't think about the original code. I'll have a look for it at lunch.
      06-29-2015, 05:57 AM   #93
darknessis
darknessis's Avatar
Hi,
It works on x64 machines too.
      06-29-2015, 07:12 AM   #94
clinton.white
Drives: 328ise F30
Hi,
Hi There - if you PM me we can establish a route to get your 1B / DE file to me and I will generate a code on my PC for you and we can compare this against your generated code.
Oh, by the way, I am running Windows 8 64 bit and the FSC generator works fine.
HTH
      06-29-2015, 07:39 AM   #95
Rockett100
England
PM sent
      06-29-2015, 01:25 PM   #96
kitster
Drives: G31 M Sport
Did you get this working?
      06-29-2015, 01:35 PM   #97
Rockett100
England
Hi Kitster,
No, not at the moment. Emailed the FSC files over to Clinton.white to see if he gets the same code as I got. I'm pretty sure i followed the instructions correctly but i did notice that my base variant was different when pulling the code off the car as i got HU_CHAMP instead of HU_CIC as the instructions discribed. Is this a problem?
      06-29-2015, 02:03 PM   #98
kitster
Drives: G31 M Sport
The champ is based off the CIC so you need to be generating a 1B file. Do you want to send me the file as well?
      06-29-2015, 02:16 PM   #99
Rockett100
England
That's what I thought so i did do the 1B file. If you don't mind looking at it I'd be grateful for your help.
      06-29-2015, 02:20 PM   #100
kitster
Drives: G31 M Sport
Can you send over the non-base64 1B fsc file? You'll prob need to zip it up to get around the attachment restriction on this forum.
      06-29-2015, 03:09 PM   #101
Rockett100
England
Hi Kitster,
Many thanks for the offer but clinton.white managed to sort out the problem. I had managed to name the FSC file with the wrong vin number. To many 4's! Once that was corrected i got the correct code and it's updating as we speak!
Many thanks to yourself and clinton. Got me out of the s**t!
      07-02-2015, 11:41 AM   #102
Mickcasey
Drives: 2.18i F22
Originally Posted by kitster View Post
<SgbmId id="NAVD_000014B9_255_002_182" SWID_FscShort="00A90007" name="Road Map EUROPE Next 2015-2" supplier="NTQ" sop="01.04.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR="">
<EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" />
<SwUpdate SwUpdateEntry=""/>
</SgbmId>
Hello how can add Turkey Next 2015 to lookup.xml file.
      07-12-2015, 01:31 PM   #103
Hughe
Drives: BMW 330d xdrive
Hi all can anyone point out where I am going wrong, followed the excellent guide, but when I get to generating code I get error NBT.EXE not present in tools?
Thanks In advance
      07-12-2015, 02:05 PM   #104
kitster
Drives: G31 M Sport
Thanks In advance
The NBT.exe file needs to be in the tools directory. Is it there?
      07-12-2015, 02:12 PM   #105
Hughe
Hi kitster apologises but NBT.exe? would that be the NBT_FSC application? only files I have in the tools folder are base64, lookup, original FSC and modified FSC. thanks
      07-12-2015, 02:47 PM   #106
Hughe
Kitster, yes got that now, but still getting the same error message? any ideas?
      07-12-2015, 02:49 PM   #107
kitster
Drives: G31 M Sport
Have you tried restarting the generator?
      07-12-2015, 02:54 PM   #108
Hughe
Yeah, restarted gen, laptop and also deleted and carried out procedure again. But still the same?
      07-12-2015, 03:17 PM   #109
Hughe
Kitster, sorted used the Generator attached to your orignal post. Many thanks.
By the way I think I bought your winter wheels for the E90 a few years ago ��
      07-12-2015, 03:28 PM   #110
kitster
Drives: G31 M Sport
A black E90? Came all the way from Wales? I had my F31 for a couple of days, and you said you where going to get one. Hope your enjoying it
