07-12-2015, 03:44 PM | #111 |
Rep 23
Yes that's it but It was originally silver probably looked black after the journey. Yes loving the new F31 much more refined. Just need to get another set of winter wheels now thou! Cheers
08-04-2015, 02:42 AM | #112 |
Rep 27
Anyone knows why the generator can't generate lifetime FSC codes? I understand how the online sellers of FSC-codes work (eg how they can do it without the fsc-file), but I can't understand why we can only generate single-use codes (for a certain map)? Anyone has an idea?
09-04-2015, 08:19 PM | #113 |
Rep 402
Drives: 2015 550i xDrive
can someone help me with the updated Lookup.xml for North America Next 2016_1 for NBT?
Instagram @_gr8dane
2015 550xi - current 2015 428xi - retired 2010 328xi LCI retired |
09-05-2015, 12:50 AM | #114 | |
Rep 1,894
<SgbmId id="NAVD_000014B8_255_002_164" SWID_FscShort="00A80008" name="Road Map NORTH AMERICA Next 2016-1" supplier="TAS" sop="01.03.2016" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> |
09-11-2015, 12:34 PM | #115 |
Rep 51
Ok, so I'm confused and probably missing something already posted! I have HU_Entrynav which is 606 Business on a UK F31 with maps Europe Route 2015-1 currently on the car.
Using Esys and the instructions in post 1 I have extracted the DF file (not DE or 1B), apparently DF is entrynav and this was the only option which got me a file anyway. I put the lookup.xml into the generator directory and loaded up my saved FSC file after running this through Base64 which seemed to work fine. The issue I have now is that I do not have Road Map EUROPE ROUTE 2015-2 in my list. I have gone round in a loop with this and I am massively confused Do I need to edit the lookup.xml file to get this in there and if so how do I go about it? Forgive what may be a simple question as suffering badly from 14 days solid work and jetlag! Cheers Demig |
09-11-2015, 12:41 PM | #116 |
Rep 40,786
You are wasting your time. Generator does not work with DF file.
09-11-2015, 03:59 PM | #117 |
Rep 51
10-16-2015, 02:38 AM | #119 | |
Rep 3
- pkgdb - config.nfm and the size is 20,5*Go, it's normal? i dont have 3 files (usb1, usb2, usb3)....??? |
10-16-2015, 04:22 AM | #120 |
Rep 40,786
That is correct. You have the Single USB version. Just copy the pkgdb folder an config.nfm file to a 32 Gb USB Drive.
10-25-2015, 03:31 AM | #121 | |
Rep 3
Guten Tag
Ich habe ein frage wir haben ein BMW F10 von 07.09.2011 und ich habe auch gestern Die FSC code gemacht und ausgelesen aber nur beim DVD/USB habe ich das hier gelesen. und brauche hilfe um das ist auch für mein auto oder nicht. Ich habe die USB-Update Road Map Europe West PREMIUM 2015-2 single USB heruntergeladen. Quote:
10-26-2015, 06:09 PM | #123 |
Rep 40,786
Or just update yours using 0x28 0x0B.
10-27-2015, 07:59 AM | #124 |
Rep 81
shawnsheridan - that is a little criptic for me
I've saved my XXXXXXX_000DE001.FSC file for the future If they did not change anything Code:
<SgbmId id="NAVD_000004CE_255_002_062" SWID_FscShort="0028000A" name="Road Map Europe East PREMIUM 2015-2" supplier="NTQ" sop="01.03.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="HU_CIC-HB" Format="CIC" /> <SwUpdate SwUpdateEntry="No"/> </SgbmId> 2016 Premium WEST Europe Code:
<SgbmId id="NAVD_000004CE_255_002_063" SWID_FscShort="0028000A" name="Road Map Europe East PREMIUM 2015-2" supplier="NTQ" sop="01.03.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="HU_CIC-HB" Format="CIC" /> <SwUpdate SwUpdateEntry="No"/> </SgbmId> Code:
<SgbmId id="NAVD_000004CE_255_002_064" SWID_FscShort="0028000A" name="Road Map Europe East PREMIUM 2015-2" supplier="NTQ" sop="01.03.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="HU_CIC-HB" Format="CIC" /> <SwUpdate SwUpdateEntry="No"/> </SgbmId> |
10-27-2015, 08:40 AM | #126 |
Rep 1,858
NBT is NEXT mapping
Shawn said on a post in the nav section Europe NEXT 2016-1 is out. I've asked him for the link http://f30.bimmerpost.com/forums/sho...&postcount=169 |
10-27-2015, 09:13 AM | #127 | |
Rep 40,786
Use 0xA9 0x08 for NEXT 2016-1. I do not have links for Map only, and the usual source for Map Torrent files has discontinued the practice.
10-27-2015, 09:33 AM | #129 |
Rep 40,786
No, I think links will appear very soon, just from a different source than the past.
10-27-2015, 12:13 PM | #131 | |
Rep 40,786
You can update to 2016-1 PREMIUM though.
10-28-2015, 08:54 AM | #132 |
Rep 1,894
Not tried the actual link myself but I have used the site before for downloads:
Europe NEXT Map 2016-1 torrent: http://cartechnology.co.uk/showthread.php?tid=10922 |
