02-25-2017, 03:27 PM | #1 |
Rep 19
+1 tire = an engine gearing ratio issue?
I just bought used 20" Style 361 wheels for a '13 328i Sport. I thought I would be able to use the mounted PZero RFs for this summer, but decided on new tires. To my shock and amazement, the set is $1500 (the 255/30 rears are $500 each).
I'm looking to going to non run-flats - my wife is not crazy about it- at the staggered 225/35 and 255/30 sizes, or going to a 235/45/20 square setup to get "reasonable" run-flats. Besides the speedo correction/0.8" taller, the only other issue that the TR rep had was an engine gearing ratio issue. What is that, and has anyone done a square setup with 20" x 8"/8.5" wheels on a F30? |
02-26-2017, 05:09 AM | #2 |
Rep 5,140
Something is wrong with your numbers, 235/45-20 is a SUV tire.
But 245/35-20 square will fit fine on staggered 8/8.5" wheels. You might like to add rear spacers to match the more aggressive front wheels. |
02-26-2017, 08:23 AM | #3 |
Rep 19
Sorry, 245/35
Thank you...Outside of seeing more rim on the back, any issues with how the tire will look on each rim (Front/back)? Also any thoughts on the "engine gear ratio" and why that would matter on a 0.8" (2.032CM) taller tire? Last edited by peteranton; 02-26-2017 at 08:28 AM.. |
02-26-2017, 08:39 AM | #4 |
Rep 5,140
The rear tire will be slightly more stretched, that's all.
I think he meant since 245/35 is 2% taller than OEM the engine will use 2% lower rpm for a given speed. Nothing to worry about. |
