10-30-2019, 03:57 PM | #1 |
Rep 4
**winter tire help** 18x8 35mm offset
Does anyone know if I will encounter any problems running 18x8 35mm offset wheels with 225/45/18 tires? Vehicle in question is a 2013 335i xDrive with M-Sport brakes (blue ones).
I've tried searching and I came across many people saying 18x8.5 with 35 offset works, but I just want to be sure the the narrower 8" rim won't present any issues with a 35 offset. Thank you in advance!! |
10-31-2019, 12:10 AM | #2 |
Rep 883
It’s not just offset, the wheel needs to have clearance with your MBrakes. Not all 18x8 et35 will clear - it depends in shape of inner wheel/hub area.
10-31-2019, 07:58 AM | #3 |
A family of bimmers
2747
Rep 7,742
18x8 et35 will sit 1mm in from stock. the issue is what visionaut stated. MBrakes do not clear all aftermarket 18s. I would test fit the rim before mounting tires up.
