03-12-2017, 10:29 PM | #1 |
Rep 239
Octane Boosting 91 to 93
Looking into new ways of further improving my n20s performance. The debate now is e85 (40% blend), or either the bms or afe meth kit. I'm leaning toward the meth kit out of convenience (and I've heard it works wonders with the 320 compression).
But in the meantime... Anyone experiment with Octane Boosters? I've heard mixed things. Mainly that they aren't very effective -- only adding a few points of octane at best. However, when running 91 octane vs say 93 octane or even 100 octane, my ignition timing consistency growth is amazing. The 320i, being slightly higher compression clearly loves the high octane. The 93 octane blend hits a real sweet spot on map 2, and I'm hoping I can fill up with 91 and add a bottle of some Octane boost with MTT. If it can safely manage to get me even two extra points of octane, that would be a cheaper way of achieving a 93 blend without having to mix 91 octane with a few $10 gallons of 100 octane. Any advice would be much appreciated! Any brands to look out for or avoid? Is there a certain amount that should be used per tank or a certain grade/quality? Any risks (fuel pump issues, etc.)? Some of these brands are as cheap as $3 a pop! Would be a great solution if it's R E A L. Thanks in advance, I noticed this topic was discussed a couple times already. I saw mike said a few helpful suggestions, but I haven't been able to get a clear picture of which brands are safe to buy, and how much to use. I think those of us stuck with 91 could really benefit from this. wishful thinking Last edited by BMWtight2me; 03-13-2017 at 03:16 AM.. |
03-13-2017, 10:49 AM | #2 |
Rep 10,509
Mixing the 100 octane has been the only reliable way I've found
BMWtight2me86.50 |
03-14-2017, 05:28 AM | #3 |
Rep 239
Any potential harm in trying out a bottle of the octane boost? Even raising it a point would help ignition timing...
I mix in a few gallons of 100 octane every third or so fill up. Keeps it peppier in general. Still a bottle of OB per fill up would be cheaper. |
03-14-2017, 01:02 PM | #5 |
Rep 1,668
Where is that Dubai?
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
donkey464.00 BMWtight2me86.50 |
03-14-2017, 01:55 PM | #6 |
Rep 4,876
Most octane boosters only raise octane 20 points (that's 2 on the octane scale). So a 91 goes to 93 with a bottle of booster. For the cost, its vastly more expensive than just filling up with 93 to start with though.
I wouldn't expect that much difference in power gains from 91 to 93 octane though. Keep in mind adding more timing doesn't make more power. Higher octane burns less aggressively, so more timing is needed for a complete burn, and doesn't necessarily net more power. |
BMWtight2me86.50 |
03-14-2017, 03:29 PM | #7 | |
Rep 239
I definitely notice the logs look smoother or more consistent with 93 vs 91. Since I have no access to 93, it's seeming like the bottle of OB could be cheaper than blending in a few gallons of 100 oct at $10 bucks a gal. Wdyt? Reliable? Safe? Close to just pulling the trigger on the meth kit (prob most convenient) or the newer jb4 with ft wires for e85. Appreciate the advice. |
03-14-2017, 04:59 PM | #8 |
Rep 3,622
15 gallons of 100 octane should do!
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
BMWtight2me86.50 |
03-15-2017, 02:04 AM | #9 |
Rep 239
03-15-2017, 01:54 PM | #10 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
lol.Ouch. There's a station on my way to my office that sells 100oct. Been afraid to pull in and the sticker shock after..lol.
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
03-15-2017, 05:28 PM | #11 |
Rep 4,876
When you check the logs, does it show timing being pulled? If it's detecting knock, it would be pulling timing, which would result in a reduction of power.
03-15-2017, 07:27 PM | #12 |
Rep 211
If you do a search on octane boosters those using them tend to favor Torco. 12 oz to 15 gallons should raise your 91 to 93. I've used it occasionally in a couple of cars with no adverse effects. I believe it will leave a red/orange residue on your plugs and some say you should change them more often if you're going to use it all the time.
Mineral Gray - Active Autowerke Stage 2 - MPerformance Suspension - VRSF CP - CTS Turbo IC - Catted Fabspeed - Akrapovic - HRE FF15
BMWtight2me86.50 |
03-16-2017, 05:00 AM | #14 |
Moon Parasite
654
Rep 1,336
If you're going to use one Torco is one of the best. But don't expect more than two or three octane increase. Plus it's really not meant to be used all the time. If you really want to keep your fuel increased that much/often I'd start trying to find someone who will order you a 55 gallon drum of race gas which would be cheaper than buying it by the gallon from a pump station.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
BMWtight2me86.50 |
03-16-2017, 07:20 AM | #15 | |
Rep 239
Won't be goin the 100 oct route except mainly for track days. Long term... Meth kit seems like the call. |
03-16-2017, 09:46 PM | #16 |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
The points are not 91 to 93. Its 91 to 91.3 Buy bulk toluene from Home Depot, Lowes. hardware store of paint store. Toluene is the primary booster in the Boosters. If you can't get Toluene get Xylene.
Use it at a 10 - 20 - 30% rate. 30% would be about 4.5 gallons to 15 gallons of gas. Each 10% will raise the octane 2 full points. Still back to basics I always use 100 octane either in a mix or straight. E85 + 92 up to about 40% is another choice. All of the above said a 320 is less likely to be able to handle as much over boost as a 328/330.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
03-17-2017, 11:51 AM | #18 | |
Rep 10,509
In the end, I decide it was easier to just mix in 3 gallons of 100 octane for every 10 gallons of 91. Cost was about $15 more per tank than just filling up with 91 |
03-17-2017, 12:07 PM | #19 |
IG @bmwF9xG80
3813
Rep 7,593
If you can't get E85 at nearby station, do Meth Injection with Boostjuice!
Recent youtube guys TheTuningSchool tested every Fuel & Liquid Injection Test.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
BMWtight2me86.50 |
10-28-2018, 12:48 PM | #21 |
3127
Rep 5,264
This is a Euro RON rating so figure the base is 91 USA. Most anyone using a booster is running toluene. Question is what percentage is safe. Its generally run between 10% & 30% when used straight up. Chart is a 20% mix. Can't help on the seals, gaskets, parts etc. I mix 100 & 93 when I need more octane. The point of the exercise is most boosters suck & the few that do anything are very very expensive.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 10-28-2018 at 01:09 PM.. |
