02-09-2017, 11:08 AM | #1 |
Rep 208
Recently I purchased and installed the AWE Carbon Fiber air intake but also have the AWE cat back exhaust, downpipe, and JB4 on my car. When in sport mode and I do a hard acceleration my car usually does a backfire/burble noise when shifting gears. When I first got the intake installed and I'd do a sort of hard acceleration my car would make the backfire noise when shifting and would shift smoothly like normal. The next day though when I accelerate the car would make a weird backfire noise and it would sort of stutter when shifting. Additionally it seems the throttle response doesn't seem as good as it was before and seems like the car holds gears longer than usual.
Overall my car just doesn't seem to be running the same even though it seemed completely fine at first. Any advice? |
02-09-2017, 03:04 PM | #8 | |
Rep 208
I appreciate your help so far! |
02-09-2017, 03:48 PM | #9 | |
Rep 190,750
Jb4 fixes it
ACR359750.00 |
02-09-2017, 04:19 PM | #10 | ||
Rep 208
02-09-2017, 07:40 PM | #11 |
Rep 208
Well I unplugged the sensor kept unplugged and took it for a ride. The difference was immediately noticeable. The throttle felt lighter, the car didn't hold the shifts longer, the sounds sounded better, and I think it's faster now and sounds better. Overall I believe it's back to normal if not better. Hopefully within the next few days to weeks it'll still be running fine and no issues will arise.
Thanks to both of you guys I appreciate it! |
mbanks211267.50 |
02-09-2017, 07:59 PM | #12 |
Rep 2,957
Congrats. Spread the word. Down with MAF!
ACR359750.00 |
02-13-2017, 06:32 AM | #14 | |
Rep 2,957
02-13-2017, 10:45 AM | #16 |
Rep 2,957
02-20-2017, 08:51 PM | #17 |
Rep 208
02-21-2017, 01:46 PM | #18 |
Rep 785
Sorry but this just sounds really lame...
In order to get a tune and an intake to work together...lets all suggest to unplug the MAF even though there is no logic, data, and even the aftermarket companies behind this "solution"??? Seems like the combo is causing an issue and unplugging the MAF is, in my mind, the equivalent to cutting your springs so you get a drop. Easy fix but you have no idea what other issues it will cause down the line. Plus it sounds ghetto. Sorry, not trying to be rude haha. |
CalCarNut1060.50 |
02-21-2017, 02:28 PM | #19 |
Big Turbo Boys N Girls
327
Rep 579
MAF is not really needed as our manifold runs on Intake pressure to calculate the right amount of fuel hence why we have a MAP sensor and is much more accurate. The MAF is a supplementary to the MAP. Both are not needed and in most cases many other makes and people who tune cars delete the MAF and run MAP for more accurate scaling.
mbanks211267.50 |
02-21-2017, 02:36 PM | #20 | |
Rep 785
You would think after spending a grand on an intake you wouldnt have to have any guess work on, should I go maf-less or not just because you have a tune. Again, maybe im off base....but seems like alot of guessing and nothing guaranteed...which is a shame for all the money the OP spent on the tune and intake. If the intake works fine on OEM tune...and Jb4 is causing it problems, would say JB4 is the issue and they need to address what should be done to run their tune with an aftermarket intake. If they say "remove the MAF" and that becomes SOP...then I guess it is what it is.. |
02-24-2017, 08:22 AM | #21 |
Rep 740
What about users with aftermarket intake and no tune? unplug the MAF as well?
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
02-24-2017, 08:32 AM | #22 |
Rep 2,957
