07-21-2022, 06:23 PM | #23 |
Rep 6,322
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.58]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
No. The emergency/parking brake has to be engaged manually.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
07-21-2022, 07:23 PM | #24 |
Rep 5,097
07-21-2022, 08:41 PM | #25 |
Rep 436
I have to agree with the others. You shouldn’t have to talk to the other insurance company. In my accident, the two insurance companies talked. I picked my repair shop. Other driver found at fault, so no deductible for me to pay. Talked to my insurance company twice was very painless.
07-21-2022, 11:15 PM | #26 | |
Rep 1,117
You can have it repaired anywhere you want. But you can easily end up paying the difference. For example, you might want it repaired at a BMW Certified Collision Center. However, their contract with BMW does not allow the use of used parts. As your car is used, Insurance is only required to find equivalent condition parts. So, if you want it repaired at a certified BMW Collision shop, odds are you will pay the difference in the used part price and the new part price. In most cases used bumpers, hood and most body parts are never used anyway. But used items such as headlights, taillights etc are often used. In this is the case, you cannot use the aforementioned BMW Certified Collision Shop unless you pay about $1k extra per headlight for a new part. Furthermore, if the rates for the shop you want used are higher than the standard rates in your area, they will write you a check based on those rates. You can go to the top end shop for repair, but can end up paying the difference. |
07-21-2022, 11:17 PM | #27 |
Rep 1,117
07-21-2022, 11:25 PM | #28 |
Rep 1,199
Nah I'm not from CA and I have no incident experience here. At least in TN and AL it works this way.
07-22-2022, 12:21 AM | #29 |
Rep 5,097
07-22-2022, 04:26 AM | #30 | |
Rep 779
07-22-2022, 04:56 AM | #31 | |
Rep 843
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
sspade2468.50 |
07-22-2022, 06:55 AM | #32 |
Rep 3,217
Replacement quarter panel on the F30 is cold bonded and riveted to minimize the possibility of corrosion and minimizing heat cycling at replacement seams (the only weld point is at the upper C pillar). A certified shop that does BMW will know this, explain it to insurance, and the car gets a new OEM panel. If this were my car that's the only concern I'd have with someone trying to use LKQ parts. Certified BMW shops will still use LKQ or aftermarket from time to time. Having said that, I don't know what year F30 OP's car is but there is a good chance this one is done for based on what I'm seeing in those photos.
07-22-2022, 02:04 PM | #33 | |
Rep 5,097
Having said that, many insurance network shops have lifetime warranty, so one option is to find CCRCs(BMW parts + processes) that are also insurance network shops(lifetime warranty). Currently there is one(maybe 2?) dealer sponsored CCRC that is also in my insurer's network, the dealer-owned CCRCs that I used to work with are no longer network shops though. |
07-22-2022, 04:01 PM | #34 | |
Rep 6,322
07-22-2022, 05:19 PM | #35 | |
Rep 3,217
You're absolutely spot on too. At the end of the day, the person doing the repair is much, much more important than where it's being done. |
07-22-2022, 08:33 PM | #36 | |
Rep 5,097
I was specific in the 2nd attempt that I was ready to report to BMWNA, and the foreman took over and the result was factory-like. There was also one repair at a top-rated Euro body shop that went wrong. They had too many jobs at the time, so my car plus the replacement parts sat in the shop for a month. When they got to do mine, the booth filters weren't replaced, so the finished paint had particles embedded below the base coat. Recently coworker did have a frame damage that other Euro shops just said it could be pulled out, but a CCRC wrote a detailed estimate with photos to backup the repair, and insurance just totaled the car with a great payout. |
07-23-2022, 12:18 AM | #37 |
Rep 97
I grew up working in an independent body shop and was an estimator there for a time. You can go to any shop you choose. You don't even have to go get their estimate. Take it to the shop you believe will fix it right. You will not get left with any portion of the bill unless you choose to do extra work beyond that caused by the accident.
By law you can go to any shop you want and it will be covered. You aren't required to get any estimates, including theirs. They just know if they can get it towed there the odds are higher it'll get repaired there, where they've negotiated better rates. If your car is in really good shape you can press the body shop to press the insurance company to use all OEM parts. My experience is that dealership body shops are usually quite poor. The best are the higher end independent shops with a great reputation. Good luck. |
07-24-2022, 12:54 AM | #38 | |
Rep 1,117
Your shop is clearly not a BMW Certified Collision Center. That’s just an example of why the broad and generic statement “you can get your car repaired wherever you want” is true in principle, but one has to pay attention to the details. There are very few instances where insurance will pay for all new OEM Parts where suitable used parts are available. The consumer ends up paying the difference if they want new parts (or OEM). As there are ridiculous markups on OEM Parts, if the overall job is worth enough to them, they will take the job and use new parts discounting them internally. But they do not have to do that. And if they are swamped and not enough hours on job, they will not match the estimate. So you an have your car repaired there, however, you owe the difference. Just one example of how the generic saying is true, but the devil is in the details. |
