06-12-2020, 08:04 PM | #1 |
Rep 847
what are these fault codes (updated with better pics)
2016 435i ZHP with about 67k miles. 100% stock, but got it used 4 years ago with 7k miles. I have no CEL and no on going issues. these are stored faults.
06-15-2020, 05:50 PM | #3 |
Rep 10,272
Is your battery still an original battery? If yes - I sense the battery may have to be replaced.
Code 213A21 is stored immediately if the voltage is less than 10 volts. Failing alternator is the usual suspect with DME being the second. Suggestions: - Replace the batter if still OEM; failing battery can trigger many codes to be stored - Clear all codes and scan for new codes within 2 days - Check wiring and all connectors to the alternator - If the voltage is still low, indy shop can diagnose the alternator performance |
06-15-2020, 11:58 PM | #4 | |
Rep 7,613
