12-07-2017, 03:43 PM | #1 |
Rep 3
Digital Fuel Gauge Problem
Dear Friends!
My digital fuel gauge (or I don't what's the name of the panel below the speedometer...) doesn't shown, as you can see on the example picture I attached. I don't think it went wrong (the car is pretty new, it has only 5.500 km), more likely I changed something in the setup menu. Do you have any tips or ideas? Thanks in advance! |
12-07-2017, 04:04 PM | #2 |
Human
932
Rep 1,200
Don't mean to be mean, but have you tried reading the manual?
2023 BMW M4 CP xDr | 510HP / 650Nm | Isle of Man Green | Photo album
Sold 2018 BMW M4 DCT / ZCP| 450HP / 550Nm | Sakhir Orange | Photo album | Tribute Sold 2014 BMW 435xd | 360HP / 710Nm | Estoril Blue | Photo album 2010 BMW Z4 sDrive35i DKG | 306 HP / 400Nm | Space Gray | Photo album |
12-07-2017, 05:00 PM | #3 |
Rep 15,858
12-07-2017, 05:25 PM | #4 |
Rep 1,560
The BC button is on the end of the turn stalk.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
12-07-2017, 08:44 PM | #5 |
Rep 4,446
Drives: '23 X1 28i xDrive
There isn't any display under the speedometer. Extended Contents display only is under the Tach. Your fuel gauge is on the left, in analog.
12-08-2017, 12:48 PM | #6 |
Rep 3
Maybe I wasn't express myself in a correct way. I didn't mean the board computer's display, but - as I mention - the digital fuel gauge(? - or range display...? I don't know its exact name...).
The BC button don't do anything with it, I suppose. And yes, there is a display: I tried to look after it in the owner's manual, but I couldn't find any helpful information. So after all, any more tips would be appreciated. Thanks in advance! |
12-08-2017, 01:48 PM | #7 | |
Rep 4,446
Top pic-- typical F30 analog display, with no contents under the speedo. Bottom pic-- either a digital dash, or not an F30 (maybe 5-Series https://paultan.org/2012/05/14/new-e...rom-july-2012/). OP had a pic of the analog display. Which has no info below the speedo. Refer to this BMW instructional video: And also this IP test video that shows all the indicator lights and IP display areas: Last edited by tex2670; 12-08-2017 at 02:03 PM.. |
12-08-2017, 03:15 PM | #8 |
Rep 1,560
If you are talking about the miles to empty as shown below (which is showing 100 miles until empty) then using the button on the end of the turn signal stalk will cycle through the options which can be displayed. If this isn't your question, then I'm not sure what you are asking about. If you google "bmw 440i instrument cluster" and then click on images maybe you can find an image showing what you are trying to display.
jeffc83725.00 |
12-08-2017, 03:20 PM | #9 |
Rep 1,615
The above two statements should answer your question OP and I was one that got pretty pissed off when I saw a "blank" there instead of a screen. (would've been a nice feature as I show speed versus DTE) Save your money and go with the digital cluster retrofit ($1600 USD) which will give you exactly what you want and a whole lot more!
Originally Posted by jmg
That seat was meant to be used, are you going to deny it's purpose in life? |
12-08-2017, 03:22 PM | #10 | |
Rep 1,615
tex26702412.50 |
12-08-2017, 05:18 PM | #11 | |
Rep 1,560
I did get mine with a full tank.
jeffc83725.00 |
12-08-2017, 05:31 PM | #12 |
Rep 1,615
Good because I was going to say if he didn't get a full tank of gas, just think of what he actually paid for the car LMAO
12-08-2017, 10:05 PM | #13 |
Rep 4,876
There is nothing on the left side on the F30. You're "estimated economy" is shown under the right dial (from battery to fuel consumed).
The MPH / l/100km will show in the center section if you cycle through the BC stalk. The left side might show miles/km's to empty if you reach critical fuel levels (not sure though). |
12-09-2017, 02:54 AM | #14 |
Rep 80
If you get the digital dash, the range is shown under the speedo, but not on the regular dash.
Even if you get the extended cluster, that part remains black.
2018 BMW 440i Coupe, High-Exec, MPPSK, HUD, Dig dash, touch-nav
2014 BMW 335, High-Exec, MPPK, MPE, HUD 2011 Audi A5 2009 Alfa 159 2005 Alfa 156 |
tex26702412.50 |
11-04-2020, 01:32 AM | #15 | |
Rep 1
Fuel Gauge and Range Display Problems
Attachment 2452900
I have the same digital dash display however of late whenever I top up, the fuel gauge display on the left shows a FULL tank while the kilometres range display shows it is not FULL. In the past, it always displays FULL similar to the fuel gauge display. I have sent to local BMW dealership, they checked and said the range display is dependent on my driving style (km/litres), if I drive hard, the range kilometres will show less than FULL. Problem is this has never happened before until of late. Has anyone experienced similar problems and found a solution? |
11-04-2020, 03:32 AM | #16 | |
Rep 15,858
04-06-2021, 09:24 PM | #18 |
Rep 19
I’d like to refresh this thread. My 2018 340i w extended digital display just decided to hide the digital fuel meter under the speedometer, and the digital real time mpg estimate under the tach. The manual says I can toggle it under displays in iDrive but the setting isn’t there.
Anyone have a suggestion I’m missing? Maybe it’s related to the trip computer or vehicle dynamics? |
Tags |
digital, fuel, gauge |
