03-06-2017, 06:45 PM | #68 |
Rep 32,881
03-06-2017, 06:54 PM | #69 |
Rep 5,897
Drives: 2014 335i Black F30 M Sport
03-07-2017, 02:38 AM | #70 |
Rep 32,881
03-07-2017, 06:30 AM | #72 | |
Rep 1,381
Do you have a parts number/requirement list? Even better a price?!
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) Last edited by fortythirtyfive; 03-07-2017 at 07:07 AM.. |
03-07-2017, 07:13 AM | #73 | |
Rep 1,235
I've also replaced with pure white LEDs which are much brighter and they illuminate the surrounding better when reversing in the dark. |
03-07-2017, 09:09 AM | #74 | |
Rep 3,863
Yea I do and will dig it up for you mate |
03-07-2017, 11:33 AM | #75 | ||
Rep 464
03-07-2017, 11:51 AM | #76 |
Rep 1,381
There's an LED module for rear and front that'll need activating, and possibly the cold/warm checks turning off.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
03-07-2017, 12:13 PM | #77 | |
Rep 32,881
Module Section Function New Value Default REM 3061 RFS_L_KALTUEBERWACHUNG nicht_aktiv aktiv REM 3061 RFS_L_WARMUEBERWACHUNG nicht_aktiv aktiv REM 3061 RFS_L_IS_LED aktiv nicht_aktiv REM 3061 RFS_R_KALTUEBERWACHUNG nicht_aktiv aktiv REM 3061 RFS_R_WARMUEBERWACHUNG nicht_aktiv aktiv REM 3061 RFS_R_IS_LED aktiv nicht_aktiv |
P1 PET396.00 |
03-07-2017, 01:56 PM | #79 |
Rep 32,881
03-07-2017, 02:01 PM | #80 | |
Rep 1,235
03-07-2017, 02:08 PM | #81 | |
Rep 32,881
REM / 3061 / BL_L_KALTUEBERWACHUNG change to nicht_aktiv REM / 3061 / BL_L_WARMUEBERWACHUNG change to nicht_aktiv REM / 3061 / BL_L_IS_LED change to aktiv REM / 3061 / BL_R_KALTUEBERWACHUNG change to nicht_aktiv REM / 3061 / BL_R_WARMUEBERWACHUNG change to nicht_aktiv REM / 3061 / BL_R_IS_LED change to aktiv Inner Brake Lights: REM / 3061 / BFD_L_KALTUEBERWACHUNG change to nicht_aktiv REM / 3061 / BFD_L_WARMUEBERWACHUNG change to nicht_aktiv REM / 3061 / BFD_L_IS_LED change to aktiv REM / 3061 / BFD_R_KALTUEBERWACHUNG change to nicht_aktiv REM / 3061 / BFD_R_WARMUEBERWACHUNG change to nicht_aktiv REM / 3061 / BFD_R_IS_LED change to aktiv And indicators if you change them too: Front left and right LED turn signals to remove flicker Module Section Function New Value Default FEM_BODY 3061 FRA_V_L_KALTUEBERWACHUNG nicht_aktiv aktiv FEM_BODY 3061 FRA_V_L_WARMUEBERWACHUNG nicht_aktiv aktiv FEM_BODY 3061 FRA_V_L_IS_LED aktiv nicht_aktiv FEM_BODY 3061 FRA_V_R_KALTUEBERWACHUNG nicht_aktiv aktiv FEM_BODY 3061 FRA_V_R_WARMUEBERWACHUNG nicht_aktiv aktiv FEM_BODY 3061 FRA_V_R_IS_LED aktiv nicht_aktiv Rear left and right LED turn signals to remove flicker Module Section Function New Value Default REM 3061 FRA_H_L_KALTUEBERWACHUNG nicht_aktiv aktiv REM 3061 FRA_H_L_WARMUEBERWACHUNG nicht_aktiv aktiv REM 3061 FRA_H_L_IS_LED aktiv nicht_aktiv REM 3061 FRA_H_R_KALTUEBERWACHUNG nicht_aktiv aktiv REM 3061 FRA_H_R_WARMUEBERWACHUNG nicht_aktiv aktiv REM 3061 FRA_H_R_IS_LED aktiv nicht_aktiv |
P1 PET396.00 |
03-07-2017, 02:28 PM | #83 |
Rep 3,863
03-07-2017, 02:34 PM | #84 | ||
Rep 4,451
Sheffield based - anyone? |
03-07-2017, 02:38 PM | #85 |
Rep 479
Four pages about LCI rear lights, proper discussion
Will be at Birmingham over following weekend. |
03-07-2017, 02:40 PM | #86 | |
Rep 464
03-07-2017, 02:42 PM | #87 | |
Rep 4,451
I'll PM you once I have the beast and we can sort something out for a few weeks time hopefully? |
Yaz_BMW320D153.00 |
